Rocker Panel Rivetts, Are they available |
jack20 |
Dec 19 2014, 09:40 AM
Member Group: Members Posts: 406 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California |
I want to remove my rockers, straighten and paint, then re-attach. Does any know where to buy the rivets? What about size and material? Can they be attached with a pop rivet tool?
Thanks, Jack |
Series9 |
Jan 17 2016, 06:30 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
Unless you have a concours car, 1/8 aluminum pop rivets are vastly higher quality than the factory part.
Mikey914 |
Jan 17 2016, 06:35 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Unless you have a concours car, 1/8 aluminum pop rivets are vastly higher quality than the factory part. Yes but if you want to remove the threasholdsfor any reason, you have to drill them out. These you push through. At the $1.50 to $3 range each you might think twice. That's why I made them. $10 a full set (both doors) you can do it right and with the correct part. |
Lo-Fi Version | Time is now: 14th May 2024 - 12:03 PM |
