tunacan.net?, Engine Displacement Chart |
VaccaRabite |
Dec 23 2014, 04:41 PM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
What happened to Tunacan.net?
Zach |
Jake Raby |
Dec 25 2014, 10:35 PM
Woody |
Dec 27 2014, 01:41 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Jake Raby |
Dec 28 2014, 11:47 AM
That one isn't MassIVe enough. Here's mine Blue are stock displacements, orange are my favorite classic combos and bold red are my current displacements. Holy crap! 112x80? What kind of dyno numbers are you seeing? Is this an engine that is supposed to last longer than 20,000 miles? With the proper machining and practices bigger doesn't mean shorter life. To fit a bore larger than 107mm you must alter the bore centerlines of the case. This is not easy to do. The 112mm cylinders are thicker than a 103mm and have the deepest cooling fins radially, with just as many fins per inch as any other LN cylinder. Anything is possible, it just gets much, much harder to create an efficient engine when it gets bigger and bigger. The only way to feed an engine like this is with Porkies heads, some twisted wedge action and splayed valves. |
Woody |
Dec 29 2014, 07:25 AM
That one isn't MassIVe enough. Here's mine Blue are stock displacements, orange are my favorite classic combos and bold red are my current displacements. Holy crap! 112x80? What kind of dyno numbers are you seeing? Is this an engine that is supposed to last longer than 20,000 miles? With the proper machining and practices bigger doesn't mean shorter life. To fit a bore larger than 107mm you must alter the bore centerlines of the case. This is not easy to do. The 112mm cylinders are thicker than a 103mm and have the deepest cooling fins radially, with just as many fins per inch as any other LN cylinder. Anything is possible, it just gets much, much harder to create an efficient engine when it gets bigger and bigger. The only way to feed an engine like this is with Porkies heads, some twisted wedge action and splayed valves. I was going to ask what the heads look like. Very cool. |
Lo-Fi Version | Time is now: 12th May 2024 - 11:34 PM |
