Who re-does gauge faces, LED's, etc. |
quadracerx |
Dec 28 2014, 01:10 PM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Id like to get my gauges re-done. White face with LED lighting, etc. Who does the best job. Do they have a website with costs?
Thanks, Steve |
GeorgeRud |
Dec 28 2014, 01:21 PM
North Hollywood Speedometer does a lot of restoration and modification work.
StratPlayer |
Dec 28 2014, 01:27 PM
StratPlayer Group: Members Posts: 3,264 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
wes |
Dec 28 2014, 01:34 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I've seen North Hollywood Speedometer over Palo Alto Speedometer a few times has any one made a comparison between the two?
Mikey914 |
Dec 28 2014, 02:15 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Well, you can replace the bulbs easily (not the Alt red light), and inexpensively, but unless you need them worked on for another reason, Tims have a few more bells and whistles, I'd send mine to him if it's just the lighting you need..
Dec 28 2014, 03:39 PM
Custom Member Group: Members Posts: 24,563 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
bandjoey |
Dec 28 2014, 04:22 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
timothy_nd28 |
Dec 28 2014, 04:51 PM
I have a couple DIY'er threads on how to integrate single or multicolor LED's inside each gauge can. I can also do it for you and include my custom controller which changes the color to red at a set RPM
rick 918-S |
Dec 28 2014, 08:59 PM
Hey nice rack! -Celette Group: Members Posts: 20,422 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Send a pm to Marks914 Mark Surel. He started a gauge company some years back. He has done several custom face gauges for me. I actually have another project for him now I need to contact him about. I need a custom gauge face made to replicate our Healey with 911 GPS speedo guts. At a glance it will look stock.
ThePaintedMan |
Dec 29 2014, 07:30 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
A +1 for Tim's (timothy_nd28) gauge service. You will not be disappointed and he can really modernize them for you. (IMG:style_emoticons/default/aktion035.gif)
Kansas 914 |
Dec 29 2014, 11:44 AM
stugray |
Dec 29 2014, 01:29 PM
I have a couple DIY'er threads on how to integrate single or multicolor LED's inside each gauge can. I can also do it for you and include my custom controller which changes the color to red at a set RPM Just out of curiosity. Did you use an arduino for the tachometer? I built one that works on either the stock ignition (tach signal) or (easier) a cleaner signal from a Mallory unilite optical pickup. I used an interrupt driven frequency counter in the Arduino. Turns my tach bright blue as a shift light. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1419881385.1.jpg) |
Dec 29 2014, 02:05 PM
I have a couple DIY'er threads on how to integrate single or multicolor LED's inside each gauge can. I can also do it for you and include my custom controller which changes the color to red at a set RPM Just out of curiosity. Did you use an arduino for the tachometer? I built one that works on either the stock ignition (tach signal) or (easier) a cleaner signal from a Mallory unilite optical pickup. I used an interrupt driven frequency counter in the Arduino. Turns my tach bright blue as a shift light. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1419881385.1.jpg) Do you have a build thread so we can see everything you have done Stu? |
Lo-Fi Version | Time is now: 25th April 2024 - 07:32 PM |
