Type 4 Case Seam, Is this normal or a repair? |
gcrotvik |
Jan 5 2015, 09:46 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I was looking over a 74 2.0 that I purchased recently. I noticed what looks to be a repair on the lower corner of the oil sump area. I compared the same area with another 74 2.0 that was very greasy (I wiped the area off but the grease in deep into the crevices). It looks to be a normal seam but I wanted to get another opinion.
See the pictures below. Is this seam standard on all type 4 cases? Thanks for your feedback. Greg Attached image(s) |
Valy |
Jan 5 2015, 10:32 AM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I was looking over a 74 2.0 that I purchased recently. I noticed what looks to be a repair on the lower corner of the oil sump area. I compared the same area with another 74 2.0 that was very greasy (I wiped the area off but the grease in deep into the crevices). It looks to be a normal seam but I wanted to get another opinion. See the pictures below. Is this seam standard on all type 4 cases? Thanks for your feedback. Greg Normal. Here is mine. |
gcrotvik |
Jan 5 2015, 10:35 AM
I was looking over a 74 2.0 that I purchased recently. I noticed what looks to be a repair on the lower corner of the oil sump area. I compared the same area with another 74 2.0 that was very greasy (I wiped the area off but the grease in deep into the crevices). It looks to be a normal seam but I wanted to get another opinion. See the pictures below. Is this seam standard on all type 4 cases? Thanks for your feedback. Greg Normal. Here is mine. Thanks! |
Mark Henry |
Jan 5 2015, 10:48 AM
I was looking over a 74 2.0 that I purchased recently. I noticed what looks to be a repair on the lower corner of the oil sump area. I compared the same area with another 74 2.0 that was very greasy (I wiped the area off but the grease in deep into the crevices). It looks to be a normal seam but I wanted to get another opinion. See the pictures below. Is this seam standard on all type 4 cases? Thanks for your feedback. Greg Normal. Here is mine. Thanks! It's normal if it's flashing, but that almost looks like a crack and welded repair. But I can only see that damage happening if it was a bus engine (rear engine) hitting something at speed. Then again the square "crack" could be flashing/casting with just odd lighting... |
stownsen914 |
Jan 5 2015, 10:54 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
If possible, try cleaning it off even more, to expose the crevice under the dark stuff as much as possible. That should let you see it better and tell whether the crevice is part of a casting mark or a crack.
rhodyguy |
Jan 5 2015, 11:08 AM
looked at some other cases in the garage. there is a flashing line at that local on all of them. shoddy work in the foundry cleanup room? i think if it was a thru crack one would be unable to keep oil from dripping all over the floor, transmission, heat exchangers, etc.
gcrotvik |
Jan 5 2015, 11:16 AM
If possible, try cleaning it off even more, to expose the crevice under the dark stuff as much as possible. That should let you see it better and tell whether the crevice is part of a casting mark or a crack. I will clean that area up Tuesday night and get more pictures. The other 74 I have looks more like the picture Valy posted. But as I said, it was very dirty and hard to see all the angles. Thanks, Greg |
Mark Henry |
Jan 5 2015, 11:29 AM
The other 74 I have looks more like the picture Mark Henry posted. Not that it really matters, but Valy posted the case pic, I just quoted the post. (IMG:style_emoticons/default/shades.gif) |
gcrotvik |
Jan 5 2015, 11:59 AM
The other 74 I have looks more like the picture Mark Henry posted. Not that it really matters, but Valy posted the case pic, I just quoted the post. (IMG:style_emoticons/default/shades.gif) Opps! Corrected, thanks. |
Mark Henry |
Jan 5 2015, 12:28 PM
I agree if that was a crack it would totally piss out oil. I know where you got it, of course check it out but don't worry about the outcome. (IMG:style_emoticons/default/shades.gif) |
bandjoey |
Jan 5 2015, 12:38 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Clean it up and fill it with JB Weld. If it's a bad molding and your worried. It does look bad in the first picture.
malcolm2 |
Jan 5 2015, 01:30 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
engine looks like it is out of the car. If you are going to open it up you can see what is on the inside in that location.
pnewman |
Jan 5 2015, 04:49 PM
Member Group: Members Posts: 371 Joined: 15-February 05 From: Lincolnshire, IL Member No.: 3,606 Region Association: Upper MidWest |
engine looks like it is out of the car. If you are going to open it up you can see what is on the inside in that location. Agreed. The interior area at the location in question should be telling. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 09:06 AM |
