FS: 914-6 OEM Engine on Ebay, ...Hmm, should I share this info or just buy it?! |
MikeInMunich |
Jan 5 2015, 02:33 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
In the spirit of sharing...
http://www.ebay.com/itm/Porsche-914-6-moto...878&vxp=mtr (IMG:style_emoticons/default/beerchug.gif) M.i.M. |
Mark Henry |
Jan 5 2015, 05:15 PM
Thats been on here before might be good for a real 914/6 but it's just 110hp
If you go down this path spend just a bit more for a running 3.2 |
914Sixer |
Jan 5 2015, 05:58 PM
914 Guru Group: Members Posts: 8,879 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Also listed on theSamba at one time.
gereed75 |
Jan 5 2015, 07:30 PM
Senior Member Group: Members Posts: 1,246 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Does not strike me as a great deal unless you really want a 2.0 liter and the seller can prove it is in very good shape (recent documented rebuild). Or if you are looking for that S/N to match your car
mepstein |
Jan 5 2015, 07:59 PM
914-6 GT in waiting Group: Members Posts: 19,261 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Won't be much longer before $7500 for a small 6 is considered a steal. Looks like a nice engine. Think about how much a nice running 4 sells for now. A good 6 should last many miles more than a 4. I have often thought if the 1.7 goes in my car, I would look for a small 6 to replace it. Leave the rest of the car stock.
haycait911 |
Jan 6 2015, 04:26 PM
Newbie Group: Members Posts: 9 Joined: 6-March 08 From: B.C., Canada Member No.: 8,782 Region Association: None |
there's at least $2k worth of webers sitting on it. with the price of a good 914-6 hitting $70k, it's not a terrible deal. especially if the number is close to what you need.
gereed75 |
Jan 6 2015, 10:47 PM
there's at least $2k worth of webers sitting on it. with the price of a good 914-6 hitting $70k, it's not a terrible deal. especially if the number is close to what you need. Agree with all, but if you are not confident that you can bolt it in and run it as is, then figure on at least the price of a seal kit to pull it apart, check it and reassemble (doing the work yourself) and at least $4000.00 if it needs set right. The only way to be confident that it is a serviceable runner is documentation of a recent competent rebuild and maybe some leakdown numbers. Without those it is a crap shoot and potentially an expensive core. Known core (no proof of being good) are getting expensive too, even small bore ones. But that number is more in line with a "good" serviceable motor, not a core. |
reharvey |
Jan 7 2015, 12:00 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
If you can't hear it run it's just a rebuildable core.
haycait911 |
Jan 7 2015, 12:34 AM
If you can't hear it run it's just a rebuildable core. yup. that's the way I figure it. if I see it run and it has good numbers, it's a running engine..... today.....maybe not tomorrow. I tend to buy running engines assuming a rebuild-able core. if not running, not even that. the problem with original 914-6 engines is that they didn't rust. whereas the cars rusted very well. so there's a lot more 914-6 engines out there than cars. and as previously mentioned, unless you have a really good reason for wanting the lowest powered flat six porsche ever built, there are many better and more exciting options out there for the buck. |
carr914 |
Jan 7 2015, 05:48 AM
Racer from Birth Group: Members Posts: 118,556 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
If you can't hear it run it's just a rebuildable core. the problem with original 914-6 engines is that they didn't rust. whereas the cars rusted very well. Magnesium deteriorates, gets brittle & breaks. This can be a lot worse than body rust |
GulleyGulley |
Jan 7 2015, 12:24 PM
Member Group: Members Posts: 67 Joined: 12-March 12 From: CNY Member No.: 14,243 Region Association: None |
I sold my good running 914-6 engine two years ago for quite a bit less. Webers, etc. No one really wanted a heavy 110hp engine when you can build a lighter and more powerful 4 banger or go with a bigger six for about the same money.
gereed75 |
Jan 7 2015, 05:08 PM
What is the correct 914-6 shroud color??
914itis |
Jan 7 2015, 06:43 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I sold my good running 914-6 engine two years ago for quite a bit less. Webers, etc. No one really wanted a heavy 110hp engine when you can build a lighter and more powerful 4 banger or go with a bigger six for about the same money. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/driving-girl.gif) |
rick 918-S |
Jan 8 2015, 05:06 PM
Hey nice rack! -Celette Group: Members Posts: 20,452 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm pretty sure black shroud and not webers. No air cleaner, no tin, and a 2.0.
Unless it's for you exact car it's just a low hp heavy engine in need of an expensive rebuild and lots of parts expensive missing parts. Good luck getting 2k for a set of unknown webers. Half that price and then a bunch of cash to get them right is a good day. We have seen these here several times over the last year. Some crazy prices like 15K and stuff (IMG:style_emoticons/default/confused24.gif) |
fixer34 |
Jan 8 2015, 05:40 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
I'm pretty sure black shroud and not webers. No air cleaner, no tin, and a 2.0. Unless it's for you exact car it's just a low hp heavy engine in need of an expensive rebuild and lots of parts expensive missing parts. Good luck getting 2k for a set of unknown webers. Half that price and then a bunch of cash to get them right is a good day. We have seen these here several times over the last year. Some crazy prices like 15K and stuff (IMG:style_emoticons/default/confused24.gif) I believe the carbs are Webers, but at least one of them is missing some parts (linkage). The shroud should be black, and mine has a gray air duct riveted to the black cover that extends back by the oil pressure sensor. As noted, a lot of the tin work is missing. Flywheel?? Distributor?? And the best part-the mounting strap for the alternator/fan is installed backwards. The label should be facing the other way. |
haycait911 |
Jan 8 2015, 10:52 PM
wrong fan assembly. which is funny because the one he has on there is worth twice what the correct one would be.
as mentioned above, correct 914-6 shroud is black with a grey air duct. don't quote me but I seem to recall the 914-6 came with Weber IDT carbs, not IDA. also, to Rick 918-S and everyone else. I'll happily pay $1k a pair for all the Webers you guys can come up with (IMG:style_emoticons/default/happy11.gif) |
Cairo94507 |
Jan 9 2015, 07:52 AM
Michael Group: Members Posts: 9,747 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That should be out of a '71 Six, right?
mskala |
Jan 9 2015, 08:54 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
The whole thing is sort-of nonsense for the price. Basically, if you have a
'71 914-6 or possibly the exact car for this engine case, then you would be a happy guy, although you would probably have zero interest in the incorrect fan/shroud, broken incorrect green shroud, incorrect carbs, and would need a _lot_ of 914-6 specific parts to complete. Or, if you don't have a 914-6 then this is just a $7500 non-running early magnesium case with unknown internals of probably low HP and you can see from the pics it is just a bunch of random parts thrown onto it (though webers have real value). The funny part that shows this was not simply taken out of running car and maybe a few parts sold off, is that the fan belt is not even tight. |
james wallace |
Jan 26 2015, 09:59 PM
Newbie Group: Members Posts: 3 Joined: 5-February 14 From: Maryland, near DC Member No.: 16,962 Region Association: MidAtlantic Region |
Hi Everyone,
The motor is sold, it brought close to asking and is going into an original 914-6. This motor was represented as a rebuildable core to all those who inquired, nothing more. It did not even come out of a running car, as I never got to see the car! The OEM Webers were Porsche OEM, but not to the the 914-6. I also made that clear to all who inquired. The only time I ever list a motor as complete and running is if I bench tested it myself, or drove it in the car. I think it's important to know what you're starting with, and who you're dealing with- considering the hours and parts to rebuild, not to mention today's somewhat difficult machining environment and the number of trips to and from! Being involved with the right guys who have been rebuilding the early Porsche motors for some 30-40 years is an immense help in pricing cores and runners in todays marketplace. If I could still buy decent rebuildable cores at 2K, I'd try to buy them all. It is quite clear as all of these P cars continue to appreciate that builders will also be paying more for their cores than in years past. Even the Webers can be upwards of 1500-2k for rebuilds. Ugh. |
Lo-Fi Version | Time is now: 12th May 2024 - 09:14 AM |
