rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 564 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
if i use a 3/8 hose to plastic pipe,what would fit in other end that could be stepped down to the .
rosenfe |
its cheaper to use tangering 90 degree step down ss line
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,209 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
so what brass pieces are you referring to?.what diameter of brass should i use? Two barbed fittings and an adapter that they both screw into. One of the right size for the larger line, one of the right size for the smaller line. You could measure the hoses or take them with you, or just convert the Inner Diameters from metric to standard to see what size barbed fittings... This will take up more room than a dedicated step-down piece, and it has two more joints that could possibly leak. So make sure you're confident in your plumbing skills before going this route. --DD |
rosenfe |
yes that would work ,thanks
Lo-Fi Version | Time is now: 31st July 2025 - 05:52 PM |
