engine swap , anything smaller then a type 4, goal being 100hp ,smallest engine possible |
thelogo |
Jan 6 2015, 11:53 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I'm desperate to ditch the 1.7
But not looking to shoehorn anything huge in there I'd prefere to have a simple install with plenty of room to spare I figured that the smallest engine possible would be an advantage So are there any tiny boxer Subaru motors Or Something that fits better then others And please weigh in Advantage and disadvantage Subaru conversion vs. Big type 4 (IMG:style_emoticons/default/WTF.gif) |
porschefile2010 |
Jan 7 2015, 12:11 AM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
You can get some pretty impressive horsepower from a 1000cc or 1200cc motorbike engine. They use them in race cars so shouldn't be a problem if you can stand the noise!.
Alphaogre |
Jan 7 2015, 12:26 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
Cam, heads, bore and stroke. Through enought money at an engin, and you would be surprised how much power you can pull out of these motors. You would be shocked on how fast they can make some of those drag bugs, and those are an even smaller displacement. The 914 is light enough, it does not take a lot to get a good power to weight ratio.
Alphaogre |
Jan 7 2015, 12:30 AM
You can get some pretty impressive horsepower from a 1000cc or 1200cc motorbike engine. They use them in race cars so shouldn't be a problem if you can stand the noise!. You can do a v8 made out of 2 hayabusa motors like the radical. (IMG:style_emoticons/default/happy11.gif) |
damesandhotrods |
Jan 7 2015, 04:39 AM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
If a 100 hp would make you happy, why worry about a big Type IV? The stock 2.0 already had 95 hp, building a 100 hp 2.0 liter would probably the fastest and easiest route.
Chris H. |
Jan 7 2015, 08:54 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Subaru and Type 4 are pretty much the same size. For 100 hp the price is roughly the same to do it correctly. You'll get much more than 100hp from the Subaru but once you source a good engine, conversion parts, etc... you could get a pretty strong 100hp type 4.
Smaller...you could look at a rotary? Been done many times. Mike Bellis has done it and Rotary '14's is nice. |
veekry9 |
Jan 7 2015, 09:09 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
The blower solves the torque curve. http://www.magnacharger.com/c-120-supercharger-kits.aspx Honda Valkrie bike engine You can see the trans input shaft and the boss above that carries the crankshaft end. https://www.google.ca/search?q=honda+valkyr...F%3B3648%3B2736 http://www.ebay.com/bhp/honda-valkyrie-parts http://stores.ebay.com/suncoastcyclesports...=p2047675.l2563 http://stores.ebay.com/Los-Angeles-Motorcy...n=1&_ipg=48 https://www.facebook.com/pinwallcycle Honda GoldWing bike engine https://www.google.ca/search?q=honda+valkyr...ne&imgdii=_ http://www.ebay.com/bhp/goldwing-1500-engine http://volksrods.com/forum/showthread.php?t=34625 At these prices and condition,hard to dismiss. Nothing simple to adapt,cutting and hacking needed. Gut the gearbox,an adapter must be made,and so on. (Illustration is an approximation,bore is 71mm,od of ring gear =?) Something like this with a heavier flywheel,modded remote oil filter and much more. Adding a blower makes for a decent output.Flat 6 SOHC 1.5L liquid cooled efi. Just add labour and sweat equity.Be the first. |
Jan 7 2015, 12:46 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Simple install? Build up your 1.7 to get the power you want. Changing to anything other than a 914 motor will be much more complicated.
--DD |
GeorgeRud |
Jan 7 2015, 12:54 PM
Mazda rotary if you want small and something that was already done before by Simpson Hybrids back in the day.
Jan 7 2015, 01:32 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Simple install? Build up your 1.7 to get the power you want. Changing to anything other than a 914 motor will be much more complicated. (IMG:style_emoticons/default/agree.gif) You can get 100HP out of your 1.7L without having to go nuts on parts used. PM McMark and ask him about his bolt-on turbo kit for the 1.7L ... (IMG:style_emoticons/default/popcorn[1].gif) |
Mueller |
Jan 7 2015, 02:20 PM
Smaller motor usually means less torque and higher rpm band for power and while car might be fairly quick in 1st gear, once you shift into second it might be a dog!
McMark added a small turbo to his 1.7 and from what I've read it made a huge improvement without going too crazy. |
Jan 7 2015, 02:26 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if your heart is set on getting rid of the 1.7 motor I would suggest either a 2056 motor built and installed by McMark (simplest) or a subaru conversion to a small non turbo motor...
rich |
Jan 7 2015, 04:53 PM
Maybe we should ask what you mean by "small"... Small exterior packaging? Small swept volume? Light weight? Fuel efficient? What is it you are going for here?
--DD |
thelogo |
Jan 7 2015, 08:51 PM
Really I'm going for reliability and the 1.7 has given me that so I shouldn't complaine
But I am disappointed with the fuel dilivery of these engines . Even know d,jet is still going strong I think just a rebuild on the 1.7 and a complete injection overhaul would make me happy But is that cost effective , vs dropping in a Subaru 2.2 or 2.5 Because I really like the water cooling cause I live in so cal And hesitate to drive the 1.7 in temps over 90 deg f. And the non d jet ,but I have a feeling the former will be much cheaper then the ladder With only modest improvements that I don't really need . I would feel terrible if I put the 1.7 thru daily rush hrour traffic to and fro work But a Subaru or other engine I really wouldn't care ....... |
thelogo |
Jan 7 2015, 09:40 PM
And yeh as mentioned in previous post
I would think the Honda goldwing flat six Would be superior to others as far smoothness , Mpg , quietness and longevity ... Like formula2 Not formula 1 |
mr2by4 |
Jan 7 2015, 09:46 PM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
Any number of modern 4 cylinder water cooled motors will get you way over 100 hp and be compact and light. Problem is that then you need to plumb in water to cool it, you lose your heater, unless you get creative there and you lose your trunk up front and/or have holes cut in your wheel wells.
Stick with a decent type4, If you want better fuel delivery, get an EFI system. There are a couple of vendors mentioned on the list with ready to go systems for less than you would spend on specialty parts to fit a Subaru or anything else. You will, however still be stuck with your transmission... |
thelogo |
Jan 7 2015, 09:57 PM
I personally like the transmission and don't intend to upgrade reguarless of powerplant
I think that 901. Is really a unsung hero ,granted mine is in pretty fine fiddle I know there are a lot of em out there that are Grind ey But I always remember to Never abuse 1 st gear and I'm good |
brant |
Jan 7 2015, 10:01 PM
914 Wizard Group: Members Posts: 11,634 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Stupid thread
thelogo |
Jan 7 2015, 10:04 PM
Maybe we should ask what you mean by "small"... Small exterior packaging? Small swept volume? Light weight? Fuel efficient? What is it you are going for here? --DD Hey yeh ... This guy has it Preferably all of the above attributes .... Really I' only freeway cruize in 5 th so great mileage is really a big plus Which as I understand as the 911 trend has shown , best mileage and pollution control Can never be achieved by , air cooling Is. This really true ????? (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/WTF.gif) |
infraredcalvin |
Distracted Member Group: Members Posts: 1,524 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Lo-Fi Version | Time is now: 4th June 2024 - 04:25 PM |
