Late Model Fuel Pump Mounting Plate, Looking for pictures of the mount and orientation |
Nozzle |
Jan 12 2015, 06:27 PM
Member Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
I am interested in mounting a new fuel pump in the late model forward location using the stock mounting bracket and plate. I've tried to find good pictures online and using the search function here to use as a reference but so far no luck.
Any help would be much appreciated. Thanks. |
Spoke |
Jan 12 2015, 07:19 PM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's how I mounted the fuel pump in the front.
Cut the fuel door by outlining the cutout with spray paint Welded a plate onto the cutout so the cutout centers the cover. Drilled holes for bolts. Welded nuts onto the inside of the fuel tank area. Used 2 hose clamps to secure the pump to the door. Dremel made some nice slots to run the clamps through. Offset the pump on the door so I could pull the pump out easily. Done. |
Jeffs9146 |
Jan 12 2015, 07:23 PM
Here is the stock one.
Nozzle |
Jan 16 2015, 10:57 AM
Thanks for the replies folks. If I can't find a stock mounting plate then the custom-built solution will probably be the best option.
Thanks again. |
Steve Snyder |
Jan 16 2015, 12:33 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
I used the stock mount and plate out of a '75 to relocate the pump to the front of my '74. It is very easy... just measure and cut a rectangle out of the front trunk divider, drill four holes for the mounting bolts and weld in four nuts. I also used the '75's stock felt with the built-in carpet bubble to cover it. It looks like it came from the factory.
I'm pretty sure I have a spare mount, plate & felt in a box somewhere. I can try to dig it up if you are interested. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:15 PM |
