Did you build yoru own adapter ?, engine-transmission |
got914? |
Jan 15 2015, 09:06 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
What was the combo ?
What tools did you have ? What were the major issues/problems ? |
Jan 15 2015, 09:30 PM
What engine? What transmission? (IMG:style_emoticons/default/confused24.gif)
I run a bone stock 901 behind a 3.6L engine. The only adapter needed is a cut ring gear for the flywheel. (IMG:style_emoticons/default/driving.gif) |
andys |
Jan 15 2015, 09:39 PM
LS1 to Audi 01E 6 speed. Though there are now a couple of people making adapter plates, there were none when I did mine. I have a vertical mill that I used to drill the hole pattern and the dowel pattern. I farmed-out the water jet, Blanchard grinding, and zinc plating work. The design work was done using Solidworks 3D modeling. The bigger problem is arranging the flywheel and clutch/pressure plate and how they stack up to work within the bellhousing (getting all the axial dimensions correct). Over-simplified description, but ask if you need more info.
Andys |
Jan 15 2015, 09:51 PM
What engine? What transmission? (IMG:style_emoticons/default/confused24.gif) I run a bone stock 901 behind a 3.6L engine. The only adapter needed is a cut ring gear for the flywheel. (IMG:style_emoticons/default/driving.gif) You run a bone stock 914 transmission. A 901 won't work in your car. (IMG:style_emoticons/default/beerchug.gif) |
timothy_nd28 |
Jan 15 2015, 09:56 PM
Jan 15 2015, 10:03 PM
You run a bone stock 914 transmission. A 901 won't work in your car. (IMG:style_emoticons/default/beerchug.gif) Sure it will! Of course, the shift linkage will be "interesting", and you'll have five speeds in reverse... (Since we're getting nit-picky... (IMG:style_emoticons/default/wink.gif) ) --DD |
Jan 15 2015, 10:06 PM
Bone stock.....
rick 918-S |
Jan 15 2015, 10:16 PM
Hey nice rack! -Celette Group: Members Posts: 20,459 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router.
Porsche 928 to 901. Attached image(s) |
Jan 15 2015, 10:23 PM
Tuff crowd tonite ... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/beerchug.gif)
veekry9 |
Jan 16 2015, 12:00 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You're awesome,I remember that from when. (IMG:style_emoticons/default/thumb3d.gif) |
Elliot Cannon |
Jan 16 2015, 01:24 AM
Tuff crowd tonite ... (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/beerchug.gif) I tellya, NO respect. Attached image(s) |
Jan 16 2015, 08:12 AM
Soon as the Cap,n stops showing off everything goes to shit again, slang and jargon will be tossed around, more Internet myths will blossom, and all of it will fall apart into a big pile of garbage.
Sorry, with Pat retiring and the Cap'n spending less time correcting everyone, what are we gonna do. Nature abhors a vacuum. |
Mueller |
Jan 16 2015, 09:56 AM
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You are not going to get anymore minimalistic than that setup! The majority of people buy an adapter and flywheel from Kennedy Engineering or one of the handful of kit manufactures like Renegade. If you have to ask how to do it, pass and buy a kit. Rick didn't ask...he went outside, took measurements and started to make chips. Back to the question.... not Porsche, but I've made a Volvo engine to Chevy auto adapter and I am currently making these adapters....Volvo FWD 5 and 6 cylinder motors to be used with a Ford T5 Mustang transmission....still not sure what motor I want in my '73 914 that will need the bus motor replaced....however if I do some oddball conversion I'll make my own stuff. Bridgeport mill (CNC) and all the related stuff one has in a small machine/fabrication shop. |
Jan 16 2015, 10:03 AM
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You are not going to get anymore minimalistic than that setup! The majority of people buy an adapter and flywheel from Kennedy Engineering or one of the handful of kit manufactures like Renegade. If you have to ask how to do it, pass and buy a kit. Rick didn't ask...he went outside, took measurements and started to make chips. Back to the question.... not Porsche, but I've made a Volvo engine to Chevy auto adapter and I am currently making these adapters....Volvo FWD 5 and 6 cylinder motors to be used with a Ford T5 Mustang transmission....still not sure what motor I want in my '73 914 that will need the bus motor replaced....however if I do some oddball conversion I'll make my own stuff. Bridgeport mill (CNC) and all the related stuff one has in a small machine/fabrication shop. What is the point of this adapter? Not knocking it, just curious seeing as I have an old p1800 wagon in the back. I already have a mint one.....have been wondering how to modernize the other one. |
Mueller |
Jan 16 2015, 10:10 AM
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You are not going to get anymore minimalistic than that setup! The majority of people buy an adapter and flywheel from Kennedy Engineering or one of the handful of kit manufactures like Renegade. If you have to ask how to do it, pass and buy a kit. Rick didn't ask...he went outside, took measurements and started to make chips. Back to the question.... not Porsche, but I've made a Volvo engine to Chevy auto adapter and I am currently making these adapters....Volvo FWD 5 and 6 cylinder motors to be used with a Ford T5 Mustang transmission....still not sure what motor I want in my '73 914 that will need the bus motor replaced....however if I do some oddball conversion I'll make my own stuff. Bridgeport mill (CNC) and all the related stuff one has in a small machine/fabrication shop. What is the point of this adapter? Not knocking it, just curious seeing as I have an old p1800 wagon in the back. I already have a mint one.....have been wondering how to modernize the other one. Volvo Whiteblock front wheel drive motor for a rear wheel drive applications...S70 motor in a 245 or 122... |
Mueller |
Jan 16 2015, 10:11 AM
Mark Henry |
Jan 16 2015, 01:52 PM
What engine? What transmission? (IMG:style_emoticons/default/confused24.gif) I run a bone stock 901 behind a 3.6L engine. The only adapter needed is a cut ring gear for the flywheel. (IMG:style_emoticons/default/driving.gif) Ring gear, you need a lathe. And it's a 914-901 |
got914? |
Jan 16 2015, 02:45 PM
I was thinking an srt4 motor to a boxster s 6 speed.
srt4 motor is 220 hp and 250 torque with lots of aftermarket ive already got the engine from my pt cruiser gt turbo kennedy only makes an adapter for 901 & 915. |
Jan 16 2015, 02:46 PM
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You are not going to get anymore minimalistic than that setup! The majority of people buy an adapter and flywheel from Kennedy Engineering or one of the handful of kit manufactures like Renegade. If you have to ask how to do it, pass and buy a kit. Rick didn't ask...he went outside, took measurements and started to make chips. Back to the question.... not Porsche, but I've made a Volvo engine to Chevy auto adapter and I am currently making these adapters....Volvo FWD 5 and 6 cylinder motors to be used with a Ford T5 Mustang transmission....still not sure what motor I want in my '73 914 that will need the bus motor replaced....however if I do some oddball conversion I'll make my own stuff. Bridgeport mill (CNC) and all the related stuff one has in a small machine/fabrication shop. What is the point of this adapter? Not knocking it, just curious seeing as I have an old p1800 wagon in the back. I already have a mint one.....have been wondering how to modernize the other one. Volvo Whiteblock front wheel drive motor for a rear wheel drive applications...S70 motor in a 245 or 122... would it work on the V8 motor from the volvo SUV too? Thinking about a turbo V8 p1800 wagon..... Rich |
914bub |
Jan 31 2015, 06:10 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I did mine. "T" square, digital caliper, bench top drill press, jig saw and a router. Porsche 928 to 901. You are not going to get anymore minimalistic than that setup! The majority of people buy an adapter and flywheel from Kennedy Engineering or one of the handful of kit manufactures like Renegade. If you have to ask how to do it, pass and buy a kit. Rick didn't ask...he went outside, took measurements and started to make chips. Back to the question.... not Porsche, but I've made a Volvo engine to Chevy auto adapter and I am currently making these adapters....Volvo FWD 5 and 6 cylinder motors to be used with a Ford T5 Mustang transmission....still not sure what motor I want in my '73 914 that will need the bus motor replaced....however if I do some oddball conversion I'll make my own stuff. Bridgeport mill (CNC) and all the related stuff one has in a small machine/fabrication shop. What is the point of this adapter? Not knocking it, just curious seeing as I have an old p1800 wagon in the back. I already have a mint one.....have been wondering how to modernize the other one. Volvo Whiteblock front wheel drive motor for a rear wheel drive applications...S70 motor in a 245 or 122... would it work on the V8 motor from the volvo SUV too? Thinking about a turbo V8 p1800 wagon..... Rich Rich The v8 is a Yamaha engine and I think is different from volvos white motors. I've converted several b20 cars to the b230ft. They go like hell. Contact me if you want more info, it's a great swap using a time proven engine. You'd wanna go to at least an m46 trans. I tore up 6 m41s with my first swap. Best, Erik |
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 AM |
