914/6 driving lights, Wiring lights to come on without popping headlights |
stuartgto |
Jan 18 2015, 11:54 PM
Newbie Group: Members Posts: 15 Joined: 17-April 13 From: 94070 Member No.: 15,777 Region Association: None |
Can anyone tell me how I can re-wire my driving lights (fog lights) to come on without having to turn on the head lights? Also, I would like to turn on the parking lights without having to turn on the head lights. Any help is appreciated.
SKL1 |
Jan 18 2015, 11:59 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
I added a relay to my '71 WAY back 40 some years ago to do just that- sure can't remember where I got it unfortunately, but sure someone from around here will.
I think someone does still make a "kit" to do that, like camp914 or Mikey. Good luck! |
mgp4591 |
Jan 19 2015, 12:48 AM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Mine do that already- I didn't know they weren't supposed to! I have no idea how they're wired but now that I know I'll make sure not to change a thing... (IMG:style_emoticons/default/shades.gif)
Mark Henry |
Jan 19 2015, 06:40 AM
Chris H. |
Jan 19 2015, 11:55 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
stuartgto |
Jan 20 2015, 11:16 PM
Thanks for the help. Although the JWest kit states it does not work on original 914/6's.
stuartgto |
Jan 20 2015, 11:31 PM
On an original 914/6, are the headlights supposed to popup if you only pull the headlight switch 1/2 way? They don't turn on,just pop up.
Socalandy |
Jan 21 2015, 12:18 AM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
rgalla9146 |
Jan 21 2015, 07:54 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
On mine, from the off position the first detent is parking lamps only, headlights remain in down position
But.... when turning headlamps off they do not go down when knob is pushed in to the parking lamp detent. That isn't normal ? |
Jan 21 2015, 09:44 AM
That's normal for later cars. Not sure about Sixes.
--DD |
toolguy |
Jan 21 2015, 12:06 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
It's just a matter of moving a couple of leads on the headlight switch.
I posted a drawing and diagram last year. . do a search, it's there somewhere. from old post I did actually, that is how they are suppose to work on a 914-6 . . the lead that controls 'head light up' to the motors is the gray wire on terminal K on the headlight switch. . . is you want the headlights to stay down until the 3rd stop on the headlight switch, move the gray lead from K to 56 on the switch. This will allow you to run your fogs with the tail and side markers on and keep the headlight down. . Handy if you're running at sundown with a bra on the car and don't want to stop and fold down the flaps. |
stuartgto |
Jan 21 2015, 02:33 PM
Thanks all again.
rgalla9146 |
Jan 22 2015, 09:45 AM
I just consulted the owners manual.
( As a last resort ) With the headlight switch in the park lamp position the pop-up lights come up, but not on. Some of us have re-positioned wires. |
stuartgto |
Apr 12 2015, 06:10 PM
From M. Henry's post, http://members.rennlist.com/demick/fogrewire.html, how do you remove the light switch? It is buried behind the dash. Can it be removed from the front?
Thanks. |
Apr 12 2015, 06:16 PM
My car has the unique option of the headlights coming on yet not popping up.
It's a new feature I discovered last year, just have not found the time to put it back to stock. |
Socalandy |
Apr 13 2015, 10:43 AM
Lo-Fi Version | Time is now: 17th May 2024 - 07:23 PM |
