stuartgto
Jan 18 2015, 11:54 PM
Can anyone tell me how I can re-wire my driving lights (fog lights) to come on without having to turn on the head lights? Also, I would like to turn on the parking lights without having to turn on the head lights. Any help is appreciated.
SKL1
Jan 18 2015, 11:59 PM
I added a relay to my '71 WAY back 40 some years ago to do just that- sure can't remember where I got it unfortunately, but sure someone from around here will.
I think someone does still make a "kit" to do that, like camp914 or Mikey. Good luck!
mgp4591
Jan 19 2015, 12:48 AM
Mine do that already- I didn't know they weren't supposed to! I have no idea how they're wired but now that I know I'll make sure not to change a thing...
Mark Henry
Jan 19 2015, 06:40 AM
Chris H.
Jan 19 2015, 11:55 AM
JWest makes a kit....$40 and it was easy to install.
Foglight flash
stuartgto
Jan 20 2015, 11:16 PM
Thanks for the help. Although the JWest kit states it does not work on original 914/6's.
stuartgto
Jan 20 2015, 11:31 PM
On an original 914/6, are the headlights supposed to popup if you only pull the headlight switch 1/2 way? They don't turn on,just pop up.
Socalandy
Jan 21 2015, 12:18 AM
QUOTE(stuartgto @ Jan 20 2015, 09:31 PM)
Yes, that's normal for a -6
rgalla9146
Jan 21 2015, 07:54 AM
On mine, from the off position the first detent is parking lamps only, headlights remain in down position
But.... when turning headlamps off they do not go down when knob is pushed in to the parking lamp detent.
That isn't normal ?
Dave_Darling
Jan 21 2015, 09:44 AM
That's normal for later cars. Not sure about Sixes.
--DD
toolguy
Jan 21 2015, 12:06 PM
It's just a matter of moving a couple of leads on the headlight switch.
I posted a drawing and diagram last year. . do a search, it's there somewhere.
from old post I did
actually, that is how they are suppose to work on a 914-6 . . the lead that controls 'head light up' to the motors is the gray wire on terminal K on the headlight switch. . . is you want the headlights to stay down until the 3rd stop on the headlight switch, move the gray lead from K to 56 on the switch. This will allow you to run your fogs with the tail and side markers on and keep the headlight down. . Handy if you're running at sundown with a bra on the car and don't want to stop and fold down the flaps.
stuartgto
Jan 21 2015, 02:33 PM
Thanks all again.
rgalla9146
Jan 22 2015, 09:45 AM
I just consulted the owners manual.
( As a last resort )
With the headlight switch in the park lamp position the pop-up lights come up, but not on.
Some of us have re-positioned wires.
stuartgto
Apr 12 2015, 06:10 PM
From M. Henry's post,
http://members.rennlist.com/demick/fogrewire.html, how do you remove the light switch? It is buried behind the dash. Can it be removed from the front?
Thanks.
r_towle
Apr 12 2015, 06:16 PM
My car has the unique option of the headlights coming on yet not popping up.
It's a new feature I discovered last year, just have not found the time to put it back to stock.
Socalandy
Apr 13 2015, 10:43 AM
QUOTE(r_towle @ Apr 12 2015, 05:16 PM)
Check your fuses!!!
