5 lug 6x15 inch fuchs?, wheel fitment on narrow bodied 914s?? |
funk |
Jan 19 2015, 02:25 AM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I found a sent of 5 lug 6 x 15 inch Porsche fuch wheels. Would they fit on a narrow bodied 914? the key word being 5 lug and I am uncertain if they are what you would call deep sixes??I've seen 914s with 7 inch wheels on narrow bodied.no fender rolling and they fit. then I have seen others where smaller sizes used and they rubbed and were no fit. Is there a way to know all the particulars of 914 narrow bodied fits??I couldn't find any blogs here. Although, I know this has been of interest on our site??
mskala |
Jan 19 2015, 07:10 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I found a sent of 5 lug 6 x 15 inch Porsche fuch wheels. Would they fit on a narrow bodied 914? the key word being 5 lug and I am uncertain if they are what you would call deep sixes??I've seen 914s with 7 inch wheels on narrow bodied.no fender rolling and they fit. then I have seen others where smaller sizes used and they rubbed and were no fit. Is there a way to know all the particulars of 914 narrow bodied fits??I couldn't find any blogs here. Although, I know this has been of interest on our site?? Yes. Also note that the 'deep six' and the other one sometimes called flat, are the exact same offset, so the fit is the same. 6x15 is a very safe bet. There is more to it than just wheels when it comes to the wider ones. Depends on a lot of things including wheel offset, camber, tire size, spring rate, and normal variance in bodywork. |
Mark Henry |
Jan 19 2015, 07:51 AM
They are what I will be using. Look at the back for the part number.
IIRC the most common 15x6 fuch rim part number ends in 020. |
napasteve |
Jan 19 2015, 09:44 AM
914 driving winemaker Group: Members Posts: 504 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
wndsnd |
Jan 19 2015, 11:41 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I am running Deep Six 15's with 205's narrow body, no fender rolling.
John |
Dave_Darling |
Jan 19 2015, 12:04 PM
There's no real way to tell ahead of time exactly what fits under a particular 914 without measuring. All of these cars vary a bit, and there is almost always more space inside of one rear fender than the other. (Not always the same side from car to car, either.)
You can measure the space compared to your current wheels and tires, and use the differences in widths and offsets and tire widths and such to approximate the amount of space a different set of wheels and tires would take up, but there are often variations in actual wheel/tire combos from the numbers you calculate. You should be safe running 195-width tires on 6" Fuchs. You have reasonable odds of 205s on the 6es fitting. You have much worse odds of 205s on 7s fitting. Note that you may need to fold over the rear fender lip for clearance in some cases, especially early cars. In later cars, the fender lip was smaller. --DD |
ConeDodger |
Jan 19 2015, 12:14 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
There's no real way to tell ahead of time exactly what fits under a particular 914 without measuring. All of these cars vary a bit, and there is almost always more space inside of one rear fender than the other. (Not always the same side from car to car, either.) You can measure the space compared to your current wheels and tires, and use the differences in widths and offsets and tire widths and such to approximate the amount of space a different set of wheels and tires would take up, but there are often variations in actual wheel/tire combos from the numbers you calculate. You should be safe running 195-width tires on 6" Fuchs. You have reasonable odds of 205s on the 6es fitting. You have much worse odds of 205s on 7s fitting. Note that you may need to fold over the rear fender lip for clearance in some cases, especially early cars. In later cars, the fender lip was smaller. --DD (IMG:style_emoticons/default/agree.gif) |
GeorgeRud |
Jan 19 2015, 12:27 PM
My early car did require a bit of fender rollingtoget clearance with the 205/60 on 6x15 Fuchs. When I replaced the tires, I went with 195/65-15 and it fits nicely and is very close to the stock rolling radius of the original tires.
horizontally-opposed |
Jan 19 2015, 01:23 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I am looking at trying to sneak 215/60R15s on 15x7 911R wheels into the rear of my narrow 914. Years ago, 205/60R15s fit on 15x6s, but I suspect some stretching is going to be needed this time...
Fingers crossed... |
Dave_Darling |
Jan 19 2015, 05:12 PM
I know at least one 74 that could not fit 205s on 7x15 911R wheels. (Original R wheels, allegedly!) The owner went with 195s, and evidently the tire people were not happy about trying to stretch 195s over 7" wheels.
Then again, we know other cars that have fit larger wheels/tires with little or no persuasion... Good luck with yours, Pete! --DD |
Jan 26 2015, 11:21 PM
Thanks, Dave! (IMG:style_emoticons/default/smile.gif)
Somewhat apprehensive, but need to repaint both sides of my car anyway, so...what's a little stretching? Thinking about 215/60R15 or 225/50R15. Or, to play it safe, 205/60R15, but there are no great choices in the third size. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:34 PM |
