WTB 140# progressive springs, where do I get these? |
Cairo94507 |
Jan 19 2015, 05:17 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Hello all:
I need a new pair of 140# progressive springs for my Six. I am buying the Bilstein Sport shocks for the car and believe those with the 140# will be a good fit for a street car. I checked with PMB, Tangerine, Elephant and GPR -no luck. Thoughts????? Should I be looking at coil-overs? Thanks Michael |
Jan 19 2015, 05:23 PM
Buy adjustable perches from Coleman racing and use the smaller diameter springs which are readily available.
Steve |
Jan 19 2015, 05:28 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Have you tried Automotion.com?
http://www.automotion.com/weltmeister-914-...or-porsche.html |
Paragon |
Jan 19 2015, 06:51 PM
Newbie Group: Members Posts: 49 Joined: 6-February 03 From: Corpus Christi, Texas Member No.: 255 Region Association: Southwest Region |
I'll check our stock in the morning.
infraredcalvin |
Jan 20 2015, 12:41 AM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Cairo94507 |
Jan 20 2015, 07:45 AM
Thanks Pat but I really need the 140#. I believe the 165# would be to heavy for what I need. Michael
puffinator |
Jan 20 2015, 08:25 AM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
Hello all: I need a new pair of 140# progressive springs for my Six. I am buying the Bilstein Sport shocks for the car and believe those with the 140# will be a good fit for a street car. I checked with PMB, Tangerine, Elephant and GPR -no luck. Thoughts????? Should I be looking at coil-overs? Thanks Michael I bought these: http://www.automotion.com/weltmeister-914-...or-porsche.html |
Cairo94507 |
Jan 20 2015, 08:48 AM
Yes- those are on my radar screen. I am also checking a couple of other options before I pull the trigger.
Olympic 914 |
Jan 20 2015, 03:02 PM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
What were the stock -6 springs rated ? #100 ?
Mike Bellis |
Jan 20 2015, 05:30 PM
I think I have a set collecting dust... Let me look around... (IMG:style_emoticons/default/idea.gif)
I'm now running 225# and I love it. |
Cairo94507 |
Jan 20 2015, 05:37 PM
OK - check and see and if you got them I would be happy to buy them off you (IMG:style_emoticons/default/beerchug.gif)
Jan 20 2015, 06:40 PM
What were the stock -6 springs rated ? #100 ? Depends on who you ask. Most retailers will tell you that 100 lb/in is the stock rate. There's an old Pano article that talks about several different spring rates, denoted by paint marks on the springs. IIRC, the lowest was in the 60 lb/in range; the highest might have been 85 lb/in. --DD |
db9146 |
May 26 2015, 08:02 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Michael,
If you add the coil-over sleeve in the rear, there are some 2.5" ID QA1 springs that are 140/250 progressives (10" tall) or some 100/200 or 130/250 progressives if a 12" tall spring work. |
scott_in_nh |
May 26 2015, 08:38 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
Thanks Pat but I really need the 140#. I believe the 165# would be to heavy for what I need. Michael That's what I thought, but all I could find/the best deal at the time was on a pair of 165#. The roads up here are pretty bad, but I love the springs! Because they are progressive, I would say they probably ride like 140#'s until you AX or hit a big pothole. |
worn |
May 26 2015, 09:19 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What were the stock -6 springs rated ? #100 ? Depends on who you ask. Most retailers will tell you that 100 lb/in is the stock rate. There's an old Pano article that talks about several different spring rates, denoted by paint marks on the springs. IIRC, the lowest was in the 60 lb/in range; the highest might have been 85 lb/in. --DD I thought that was true - which seems odd because it seems like the 4s are running stiffer springs. There must be an explanation. I know that the original six was not an exceptionally heavy engine, but it must have weighed at least a little bit more than the 4. I know that info is readily available here - too lazy to look it up and besides I think the main part of the statement is true. So were the 4s sold with even lower spring rates than 100? Also, how have the coleman springs panned out for anyone using them? I have the same issue to resolve for my 3.2. Soon as I finish the oil tank the motor goes in. |
Lo-Fi Version | Time is now: 15th May 2024 - 10:20 PM |
