Things to do with Gurney wheels |
jarred |
Jan 20 2015, 01:32 PM
Newbie Group: Members Posts: 20 Joined: 13-March 09 From: seattle Member No.: 10,159 Region Association: Pacific Northwest |
These are Gurney-like wheels, probably by Western. Bought the wheels and ran into the usual trouble of not being able to find the right lug nuts. So:
Option #1 you can get 14-12mm conversion lug studs then run the standard washer-ed lug nuts for 12 mm. This is about $40 in ebay parts. Option #2 I machined holes to press in steel inserts for 14 mm 60 degree taper lug bolts. Cosmetically either method works, one can maybe argue the 14 mm bolts are better. But there are about a zillion modern cars running around on 12 mm studs. Also, I welded up curb rash on these rims. If you have access to a tig welder, just use 5000 series rod then file and sand it out. The welding doesn't need to be pretty. Small scuffs can just be sanded and polished. I cnc machined the center bits. The porsche caps are off of a 928 I believe with the OD turned down, faces polished, and crest stuff sprayed black. Need to redo the cnc work since my original design doesn't clear the front hubs. Oops. Painted the inside of the rims black for contrast. Anyway, I like the look of these rims on the car. |
championgt1 |
Jan 20 2015, 01:35 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Very nice. Is your car gold?
jarred |
Jan 20 2015, 01:45 PM
Yes, gold. Original color was silver I think. Then red, then gold, then gold again. The gold that is on it now is a Porsche color. I don't remember which model of Porsche, can't say I've ever seen gold running around on another Porsche. But it's a great color for the 914.
sfrenck |
Jan 20 2015, 02:35 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Where did you get the center caps for them?
jarred |
Jan 20 2015, 02:50 PM
Made the round outside thing, the centers are polished up 928 caps.
Olympic 914 |
Jan 20 2015, 02:55 PM
Group: Members Posts: 1,671 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Very nice. I ran these for years... never could find centers that fit. good job.
rick 918-S |
Jan 20 2015, 04:01 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nice color! (IMG:style_emoticons/default/drooley.gif)
Mark Henry |
Jan 20 2015, 04:22 PM
I had those in 14" bus, I liked them I just never had the bus for them. I dragged them to shows for years couldn't get rid of them.
Then one show I almost didn't bother taking them, packed them last minute just because I had room. I got there and hadn't even unloaded and there was a guy blowing his load over them...I don't think he got the "how much?" out before I said "SOLD!" Then within a 1-2 weeks I had a couple of guys phone asking if I still had them (IMG:style_emoticons/default/dry.gif) |
jarred |
Jan 20 2015, 05:43 PM
Paint by Maaco. Friend of mine manages the place. He put a little "pixie dust" in the base coat so it has some sparkle; a tiny bit "Hot Wheels" when viewed closely in bright sunlight, but I think it totally fits the car. Definitely gets a lot of attention. Although probably not for the "numbers matching" crowd. |
aharder |
Jan 20 2015, 07:01 PM
Advanced Member Group: Members Posts: 4,395 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Nice !!!! (IMG:style_emoticons/default/beerchug.gif)
I have a set but they don't look that good !! |
URY914 |
Jan 20 2015, 08:09 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lo-Fi Version | Time is now: 20th May 2024 - 01:00 PM |
