I found the rust!, : ) suggestions? |
914Next |
Jan 21 2015, 09:09 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
This is the extent of the rust that I have found on the car so far....and I have looked quite hard. Have not removed the rockers because they are still held on with the original rivets. I did loosen the bottom screws, however and bang on the rockers knocking quite a bit of dust out...not rust or scale. Then I used a scope to go in through the rear wheel well to see what lurked behind the rocker. Looks very clean...dirty and a bit of what may be some slight surface rust but red painted surface in most areas I can observe.
So...what should I do, if anything about the rust in the pics? I will say the car will not be getting wet so I'm tempted to leave as is. Trying to keep the car as is to the extent possible. Can I safely leave these spots or do I need to repair. If repair? What is the best way to do it? Thanks. Wow. Thanks for the guidance on the posts, guys. Simple once you know how. I added a few additional pics of the jack post areas. I'll continue to contemplate taking the rockers off but given what I see, I'm more likely to leave them as is. Not concerned about rust underneath. May even take a video and post what I see in there with the scope. Attached thumbnail(s) |
Claus Graf |
Sep 15 2015, 10:53 AM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
Be afraid, be very afraid of what is underneath.....
Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 03:19 AM |
