This is the extent of the rust that I have found on the car so far....and I have looked quite hard. Have not removed the rockers because they are still held on with the original rivets. I did loosen the bottom screws, however and bang on the rockers knocking quite a bit of dust out...not rust or scale. Then I used a scope to go in through the rear wheel well to see what lurked behind the rocker. Looks very clean...dirty and a bit of what may be some slight surface rust but red painted surface in most areas I can observe.
So...what should I do, if anything about the rust in the pics? I will say the car will not be getting wet so I'm tempted to leave as is. Trying to keep the car as is to the extent possible. Can I safely leave these spots or do I need to repair. If repair? What is the best way to do it? Thanks.
Wow. Thanks for the guidance on the posts, guys. Simple once you know how. I added a few additional pics of the jack post areas. I'll continue to contemplate taking the rockers off but given what I see, I'm more likely to leave them as is. Not concerned about rust underneath. May even take a video and post what I see in there with the scope.
Click to view attachment Click to view attachment Click to view attachment Click to view attachmentClick to view attachment Click to view attachment
