Will fuel injection work with a 1911cc engine, with an 86a grind cam? |
stevegm |
Jan 21 2015, 03:15 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I have a 1911cc engine that has an 86a grind cam. The specs for the cam are here:
http://vwparts.aircooled.net/Web-Cam-Type-...-5-p/00-082.htm I am trying to figure out if this engine (1911cc), and cam, will work with D-jetronic fuel injection. Anybody know or have experience with this? |
914werke |
Jan 21 2015, 03:22 PM
"I got blisters on me fingers" Group: Members Posts: 10,080 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I believe the 86 is for carb's & the "a" is for FI, so yes it can work with D-Jet and a correctly configured 1911.
Ive done it (IMG:style_emoticons/default/smile.gif) although my engine didn't use that Web cam |
malcolm2 |
Jan 21 2015, 03:23 PM
I have a 1911cc engine that has an 86a grind cam. The specs for the cam are here: http://vwparts.aircooled.net/Web-Cam-Type-...-5-p/00-082.htm I am trying to figure out if this engine (1911cc), and cam, will work with D-jetronic fuel injection. Anybody know or have experience with this? I have the 1911 with L-jet. I adjusted the AFM gear about 11 teeth IIRC. Found the how-to online. I'll see if I can find it, there may be some D-jet info there too. I have a Daily Driver Cam from TIV store.com, #9550 and went with Jake's recommendation on CR of less than 8. Can't help with the D-jet, but as you know the World will come to the rescue. |
Mark Henry |
Jan 21 2015, 03:34 PM
I'm pretty sure it won't, too much duration. But I've never used this cam.
It looks a lot like a Scat C-25 which is a mild carb cam. Would work good with a d-jet intake with MegaSquirt. |
Mark Henry |
Jan 21 2015, 03:38 PM
I have a 1911cc engine that has an 86a grind cam. The specs for the cam are here: http://vwparts.aircooled.net/Web-Cam-Type-...-5-p/00-082.htm I am trying to figure out if this engine (1911cc), and cam, will work with D-jetronic fuel injection. Anybody know or have experience with this? I have the 1911 with L-jet. I adjusted the AFM gear about 11 teeth IIRC. Found the how-to online. I'll see if I can find it, there may be some D-jet info there too. I have a Daily Driver Cam from TIV store.com, #9550 and went with Jake's recommendation on CR of less than 8. Can't help with the D-jet, but as you know the World will come to the rescue. I believe 9550 was a djet FI cam, a modified WEB73 |
Mark Henry |
Jan 21 2015, 04:06 PM
Would work good with a d-jet intake with MegaSquirt. I'm soon going to put up for sale a set of modified 1.8 manifolds that allow you to mount all the 2.0 d-jet parts (plenum, TB, air cleaner, etc) on 4 bolt heads. Then you could megasquirt the engine. This is a known running combo that I ran with a 2.0 scat C-25cam with SDS FI and later a stock 1.8 I also might still have all the intake/injector bits, just no brain. PM me if interested. |
Woody |
Jan 21 2015, 09:05 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
That cam will not work with factory injection
Jake Raby |
Jan 21 2015, 10:28 PM
It'll run fine... At wide ass open throttle! You'll have no idle, no midrange and no tenability, though.
Lo-Fi Version | Time is now: 20th May 2024 - 12:10 PM |
