Have a little problem and need guidance and help. |
914GTSTI |
Jan 24 2015, 09:03 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
So, I have this long time ,not finished project . (thats a under statement !) Today I got some tires so I could move it around and put it up on the rack. (didn't have a rack when I started. ) Last time I worked on it I had done some soda blasting. ( Harbor Freight tool. ) I started doing some general clean up.(that stuff gets in every where.)After that I put it up on the rack. And had a look around.
This car came from Texas and to my glassed over eye's,almost no rust ! Can this be ? I kept looking and it just looked better and better. ( after seeing some of the car's being repaired here I figgered the worse. Here is my dilemma. I want a 914 GT like the Lufthansa race car. I was going to use a Subaru STI motor and have the Kennedy stuff for the trans. ( got the car with no motor or trans) Having been at it for so long, things have changed and may go with the Subaru trans ? With all the good steel in this chassis l'm thinking I will need to go steel flairs. Instead of the Glass . Or is it better to just leave it stock ? I don't like the stock power. (had one in 79 almost new) And their is the front fender/driver side hit/repair to think about. She will never be a original.I'm rambling ! Stay stock ? Build a wantabe ? Other ? Here are some shots of the steel.(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422155029.8.jpg) What do you all think ? Thanks,Randy |
914GTSTI |
Jan 24 2015, 09:22 PM
A little more info. I can't see spending the money for a 911 6 motor and the stuff that will need to be added. It will never be a 914-6. That is why the Subaru idea. And I like the Subaru motor system.
May even look into a EG33 ? Love the sound ! |
Hank914 |
Jan 24 2015, 09:26 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
"What do you all think ?
Thanks,Randy" Well, my personal thoughts are: 1- get it drive-able first 2- stuff any engine in it 3- upgrade the engine to satisfy your soul afterward Things like: Narrow body versus wide Porsche four versus six banger Suby versus SBC ...and other things... are all ideas to ponder after the jack stands are back in the closet. Those ideas are best pondered with a fine red wine while the hair is still disheveled and the whine of the drive is still ringing in your ears. A day spent out driving with the top off is a good day indeed. |
mepstein |
Jan 25 2015, 08:46 AM
914-6 GT in waiting Group: Members Posts: 19,254 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Get it running then tackle one upgrade project at a time.
lsintampa |
Jan 25 2015, 08:56 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
IDK,
I'd decide on what body style you want first. Wide body, narrow, etc. and focus on that first. Once the body is in order, your motor options are pretty much wide open. If it were me in your shoes, I'd throw out "stock" and go with maybe a Raby's motor or some other "enhanced" setup that would be a easy "fit". OH, maybe a budget first, some estimates that you need to double. Then go (IMG:style_emoticons/default/driving.gif) |
76-914 |
Jan 25 2015, 09:52 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Assess the body repair first. That jack point is not all you'll find. That corner area beneath the batt tray looks suspicious also. Take a pic from the top looking down into that corner. Poke around with the ice pick if unsure. With power upgrades come chassis upgrades. Suby is a fine choice and makes the car "very affordable to own" as well. The EG33 is a proven design and readily available. There may be some issues with Cold Waters cradle and the EG (IMG:style_emoticons/default/confused24.gif) It is the heavier and larger of the Suby 6's. Chris H. as well as Bigkat83 here, have done this conversion and might be of help.
914GTSTI |
Jan 25 2015, 12:35 PM
Will need to get a shot of the passenger side battery area.
Their are some small pin holes at the driver side rear,outer floor and passenger side front,outer floor. (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422210924.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422210925.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422210925.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422210925.4.jpg) |
914GTSTI |
Jan 25 2015, 06:58 PM
Hell hole ??
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422233924.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422233924.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422233924.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422233924.4.jpg) |
rick 918-S |
Jan 25 2015, 08:59 PM
Hey nice rack! -Celette Group: Members Posts: 20,441 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nice car to start with. Check that suspension ear carefully. It looks cracked but could just be the paint.
914GTSTI |
Jan 25 2015, 09:17 PM
Thanks,Rick. I'm hoping it will work ? So good so far .
Yep,the white paint is coming off in big flakes. Randy |
rick 918-S |
Jan 25 2015, 09:25 PM
Thanks,Rick. I'm hoping it will work ? So good so far . Yep,the white paint is coming off in big flakes. Randy Ya, made the ear look cracked in that photo. There is a few issues but there are guys here that are drooling right now. Get busy. My suggestion, don't make a big project out of it the first time around. |
914GTSTI |
Jan 25 2015, 10:04 PM
Like this ?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i257.photobucket.com-8123-1422245042.1.jpg) Locost 7 from scratch using 5.0 and T5. Thanks for the advice but I'm just not that smart . (IMG:style_emoticons/default/blink.gif) If you check my post I have been all over the map with ideas. (IMG:style_emoticons/default/drunk.gif) I'm going to try and stay on the path ? (IMG:style_emoticons/default/chair.gif) Thanks,Randy |
EdwardBlume |
Jan 25 2015, 10:12 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Looks solid.
You should realize that whatever you do, you're going to blow through any budget. The 914 is a blank canvas and a lousy investment. Build it the way you want to. If money is an issue, you'll likely never finish. I'm a fan of the P/6 even though there are way better power to cost options. What would be cool is a Boxster powered 914 but that's not something that has been done yet, likely for a reason. |
914GTSTI |
Jan 26 2015, 02:14 PM
Going to move back to my build page.
Another Sti build. Building my 914GTSTI Thanks for the input ! |
d914 |
Jan 26 2015, 02:37 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
3.0 liter suby six w suby trans six is a nice way to go.. Nice power
Lo-Fi Version | Time is now: 3rd May 2024 - 09:58 PM |
