Porsche 914 engine cross bar mount, Cross Bar |
91422.7 |
Jan 24 2015, 09:12 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I have a 1970 Porsche 914 that I'm putting a 1974 2.0L 4cyl Porsche 914 engine back into. Is the engine crossbar that supports the engine the same no matter if your using a rear mount or side mount transmission? Thanks
zambezi |
Jan 24 2015, 09:25 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
No. The crossbars are different.
Hank914 |
Jan 24 2015, 09:33 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Yes, the support bar for a side shift has a hole in it for the shift linkage bar to go thru. A bit different with the tail shift support bar. I'm sure you can find pics around here. I have a tail shift support bar if you need one, but I think here are lots of them, since people go from tail to side shift much more often.
TargaToy |
Jan 24 2015, 09:37 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
The hardware for mounting the bars to the car's engine mount consoles is also different. Early cars (tail shift) have the vibration isolators at each end of the mount bar. Later cars are hard mounted on the ends and have a rubber isolators where the motor bolts to the bar in the middle.
bdstone914 |
Jan 24 2015, 10:25 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
.Edit Sorry i misread your post. Thought you were putting a early trans in a laye car. Go with what Dave said. You also need the three shift boots for the side shift linkage. Bruce |
Dave_Darling |
Jan 24 2015, 11:10 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If you're keeping the tail-shifter in the early car, keep all of the linkage, plus motor mounts and such.
If you're changing over to a side shifter, you'll need: - Side-shift trans - Complete shift linkage: Rear rod, front rod, coupler, and even the gear shift lever - Late motor mount - Rubber inboard mounts & brackets - Solid outboard mounts & brackets - Converter bushing for the hole in the firewall --DD |
maf914 |
Jan 26 2015, 08:57 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Here are the two type 4 engine bars, late model side shift above, early model tail shift below.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st May 2024 - 08:56 AM |
