Steel framed gantry engine lift or ? |
Mueller |
Jan 31 2015, 05:24 PM
malcolm2 |
Jan 31 2015, 05:33 PM
I call that stuff, "grown man erector set" the strut nuts fit in the strut, might have springs on them to hold the nut close to the mouth of the strut. 9/16" wrench will loosen the bolt and you can remove the brackets.
Lay it down first, so it does not fall on you. |
Mueller |
Jan 31 2015, 05:40 PM
I call that stuff, "grown man erector set" the strut nuts fit in the strut, might have springs on them to hold the nut close to the mouth of the strut. 9/16" wrench will loosen the bolt and you can remove the brackets. Lay it down first, so it does not fall on you. Nope... no girly man 9/16" wrench.... 3/4" manly sized wrench needed! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:47 PM |
