Stoddard producing new 914-6 heat exchangers, Appear to be high-quality factory reproductions |
bigkensteele |
Sep 11 2015, 09:31 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Well, my first preliminary check tonight is somewhat discouraging. I took a small level and laid it across the flanges to see if they were on or close to a plane. They are not. QA is a thing of the past ... (IMG:style_emoticons/default/sad.gif) Yeah, that was my thought is well. How hard would it be to pass it through a QA station where somebody simply placed a jig across the flanges to verify that they are flat and the holes line up. Is that really too much to ask when these things cost three thousand freaking dollars?!?!? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) |
toolguy |
Sep 11 2015, 09:52 PM
QUOTE Yeah, that was my thought is well. How hard would it be to pass it through a QA station where somebody simply placed a jig across the flanges to verify that they are flat and the holes line up. Is that really too much to ask when these things cost three thousand freaking dollars?!?!? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/headbang.gif) When I had the initial problem 6 months ago and reported it to Stoddard, I made them a bolt stud location pattern and sent it to the man who was supposedly in charge of their Six exchanger program. . They have that pattern, and said they would check every set they received before being shipped to customers. . apparently seeing the latest newer pictures they still haven't got the assembly process figured out. . From talking with them, they said the tubes were assembled on a jig. . my guess is they are flexing the tubes to weld the collector flange, and when the heat distortion cools at the fixed welded collector, the head mount flanges become out of specs. . You'd expect the guy welding the mess would realize when he tries to pull the set off the jig and they stick on the studs, something isn't quite right and remove them from shipping. . For what it's worth, no way would I torque a stud in an aluminum head enough to pull that crooked flange parallel to the port. . just asking for trouble and exactly who is going to have to pay to fix your stripped head stud hole. . |
Cairo94507 |
Sep 11 2015, 09:57 PM
Michael Group: Members Posts: 9,722 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That is disappointing. How hard would it be to mill the flange flat, assuming the bolt holes are in the proper orientation?
toolguy |
Sep 11 2015, 10:03 PM
That is disappointing. How hard would it be to mill the flange flat, assuming the bolt holes are in the proper orientation? Milling it would take 5 minutes. . however figuring a way to fixture it on the mill table and the other flanges without distorting then from their 'relaxed ' position would be a nightmare. . I've been a machinist for years and I can't imagine a realistic way of doing it given the sheet metal heater box under the flanges. . nothing to grip. . . Then again, for 3 grand they should be perfect outta the box. . and if you screw up the exchanger I'd bet they be non returnable. . |
Maltese Falcon |
Sep 12 2015, 01:08 AM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Agreed, once the upper and lower stamped metal shells have been crimped in place; it's game over for holding the HB in a machining/milling operation. That is, if you really don't mind having all of the clamping dents in your once handsome $3,000.00 heater boxes.
Even while holding spec in hot welding jigs, if released too soon from the jig to cool down, primary header tubes move like snakes. Several normalizing techniques are used to bring back into spec, a slight amount of surfacing and all is well. Like Toolguy said, once the metal shells are on where do you place the hold down clamps ? Idea (IMG:style_emoticons/default/idea.gif) how about; QC the primaries after welding, then crimping on the shells. Example part that we build, the v10 BMW m5/m6 pulse tuned headers. We use welding jigs and then we bolt each header into cooling jigs. Final flange surface machining is only a razor thin cleanup. QC is just part of the job (IMG:style_emoticons/default/biggrin.gif) |
Sep 12 2015, 05:51 AM
914-6 GT in waiting Group: Members Posts: 19,251 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would not touch them but call stoddard for a call tag to pick up and refund money in full.
Cairo94507 |
Sep 12 2015, 06:13 AM
All I want for Christmas is a set of Marty-made heat exchanger/headers for my Six. Damn, those are beautiful (IMG:style_emoticons/default/drooley.gif)
rick 918-S |
Sep 12 2015, 07:37 AM
Hey nice rack! -Celette Group: Members Posts: 20,431 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I would think the jig would require holding both the muffler flange and the head flanges at the same time. I wonder what they are doing with the rejects..... (IMG:style_emoticons/default/idea.gif)
Peashooter |
Sep 12 2015, 08:14 AM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
What you need is a machine similar to what I saw during a visit to Ollie's shop. It is basically a large custom made belt sander that they use to resurface the case halves. That way you could level out all three flanges at once.
Sad to hear of the poor quality for a premium price! |
Mikey914 |
Sep 12 2015, 08:50 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
No good deed goes unpunished. I worked out a deal for Ken to get these as a thanks for help on the dash, I just dropped them an email. Sorry for the Hassle on this Ken. I hope we can get this resolved shortly. I'm sure Stoddard will do the right thing.
Mark |
sbsix |
Sep 12 2015, 02:37 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 449 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
I just got mine a couple of weeks ago, but it will be a LONG time before I install them. Is it safe to assume that they would be the corrected version? I am a bit nervous now. Toolguy on this forum has a template for fitment based on his OE HEs. I would email him to ask for a paper copy to transfer to plexiglas to double check the Stoddard replacements. Actually, after I posted, I realized that I still have the 911 exchangers that came with the motor, so I can make my own template. I plan on doing that this weekend and reporting back. Well, my first preliminary check tonight is somewhat discouraging. I took a small level and laid it across the flanges to see if they were on or close to a plane. They are not. These last two are of the 911 unit that came with my motor. MUCH more level. I think that I have some 1/8 plate around the garage somewhere. If I can squeeze it in this weekend, I will make a jig and see if the bolt holes line up and how much force it takes to bring these into plane. However, given that they are visibly out and it is steel (exchangers) vs. aluminum (heads), I don't know that I want to live with that kind of stress pulling at my exhaust studs. More to come... The picture of your "new" Stoddard/Dansk HE shows the original problem with the first sets they sold. If they didn't fix the issue about level flanges I doubt if the bolt holes line up either. I'll let everyone know what my second set looks like when I get them this coming week. |
bigkensteele |
Sep 12 2015, 06:47 PM
No good deed goes unpunished. I worked out a deal for Ken to get these as a thanks for help on the dash, I just dropped them an email. Sorry for the Hassle on this Ken. I hope we can get this resolved shortly. I'm sure Stoddard will do the right thing. Mark Thanks, Mark. I am certain it will get worked out. |
Mark Henry |
Sep 12 2015, 10:38 PM
All I want for Christmas is a set of Marty-made heat exchanger/headers for my Six. Damn, those are beautiful (IMG:style_emoticons/default/drooley.gif) Really sucks about the fitment of the Stoddard/dansk exchangers, hard to understand why QC would miss this before it went out the door. Marty has said in the past that he wasn't interested in reproducing heat exchangers. I have a set of Marty's headers and the quality is top notch to say the least, but the design would be not the best for a heater box retrofit. He would be looking at a total redesign of the headers, so essentially he'd be starting from scratch. |
Per Schroeder |
Sep 14 2015, 12:04 PM
Newbie Group: Members Posts: 13 Joined: 7-January 14 From: Avon Lake Ohio Member No.: 16,849 Region Association: None |
That is hard to understand, as we worked out the template with Toolguy and bolted the jig to every single one we received back from customers---and they were sent back to Dansk for retooling---Dansk scrapped them all and made new ones which are on the way back to our customers at this time.
The new ones come with a template/jig bolted to each and every one. I believe you may have one of the original batches sold to one of our dealers. We didn't receive all of the original ones back from the dealers. Give us a call (800) 342-1414 and we'll make it right. Attached thumbnail(s) |
scotty b |
Sep 14 2015, 12:11 PM
Not to pile on ( but I will ) ...... I have been having constant issues with Dansk body panels the last few years. The last 911 door skin I got had to be cut and widened almost 1/8 inch just to fit over the original inner shell. I'm not sure what is going on with the QC over there, but it's starting to look like the U.S. and Chinese factories have taken control (IMG:style_emoticons/default/hide.gif)
rick 918-S |
Sep 14 2015, 12:17 PM
Way to step up. (IMG:style_emoticons/default/beerchug.gif) Sucks when stuff like this happens but it's how it's dealt with that makes the story a happy ending. I would love to pick through their scrap pile. (IMG:style_emoticons/default/biggrin.gif)
Cairo94507 |
Sep 14 2015, 12:22 PM
I have to applaude Stoddard for stepping up to the plate to address this fitment issue. Hopefully the OP received one of the original new sets and not the corrected version. I look forward to someone posting after receiving the corrected set to see how fitment is. Thanks Stoddard.
Eric_Shea |
Sep 14 2015, 12:30 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
That is hard to understand, as we worked out the template Toolguy and bolted the jig to every single one we received back from customers and they were sent back to Dansk to retooling---Dansk scrapped them all and made new ones which are on the way back to our customers at this time. The new ones come with a template/jig bolted to each and every one. I believe you may have one of the original batches sold to one of our dealers. We didn't receive all of the original ones back from the dealers. Give us a call (800) 342-1414 and we'll make it right. We got two sets in for customers and they bolt right on now: Stoddard did everything by the book to make it perfect. Our new ones came with the jig attached. (IMG:style_emoticons/default/beerchug.gif) |
dcheek |
Sep 14 2015, 12:38 PM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
You guys crack me up.
You pay $3000 and you want them to fit? Don't you think you're asking too much? Ahhhh.....sarcasm.... the lowest form of humor. Makes you really appreciate how well made these cars were originally. There is no way the factory would tolerate such a defect, and why Porsche is so particular with its parts and parts suppliers. Can you imagine what it cost to replace all those porous Boxster engine blocks?! Dave |
bigkensteele |
Sep 14 2015, 02:43 PM
That is hard to understand, as we worked out the template with Toolguy and bolted the jig to every single one we received back from customers---and they were sent back to Dansk for retooling---Dansk scrapped them all and made new ones which are on the way back to our customers at this time. The new ones come with a template/jig bolted to each and every one. I believe you may have one of the original batches sold to one of our dealers. We didn't receive all of the original ones back from the dealers. Give us a call (800) 342-1414 and we'll make it right. Just got off the phone with Pete. Sounds like this will have a good ending. Thanks, Per. |
Lo-Fi Version | Time is now: 1st May 2024 - 10:58 PM |
