Ultrasonic parts cleaners, For a garage? |
Randal |
Feb 6 2005, 10:14 PM
Guess there is lots of stuff for companies, but how about an affordable unit for the garage that can clean parts?
vortrex |
Feb 6 2005, 10:18 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
jay leno was bragging about his. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
McMark |
Feb 6 2005, 10:56 PM
There are ultrasonic jewlery cleaners that will work for small parts. What'cha wanna clean?
dmenche914 |
Feb 6 2005, 11:16 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Yeah, they do work, got to be very careful with light cast alloys, (like carb bodies) cause to much power for too long will start eating away at the metal.
Aircraft brand paint striper for about any paint, and berryman Chem dip carb cleaner over night soak follwed by water, then paint thinner with some elbow grease usually get thru about any gunk. |
mightyohm |
Feb 6 2005, 11:30 PM
For the guys that use the small jewelry size cleaners, what do you put in them (solvents?)
I have a lab grade ~ 1 liter sized unit that I want to use. |
Britain Smith |
Feb 7 2005, 12:53 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I have an old ultrasonicator in my garage that I got from the chemistry lab in grad school. I fixed the heater switch from smoking and its good as new. You should just use acetone as the solvent and heat. If you have some stuff to clean up nice, bring it over with some acetone and give it a try.
I used it for all the parts of my transmission and they all look nice a pretty now. Best of all, they are free of dirt, grim, and grease!! (IMG:http://www.britainsmith.com/Porsche/912Project/Transmission/images/162_0002_JPG.jpg) -Britain |
Carrera916 |
Feb 7 2005, 02:34 AM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
these ultrasonic tanks are GREAT!!! ...especially the heated ones...
my old man had one from a radiator shop and we used them like crazy on almost everything that could be fit in... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif).......we just used water and detergent as it does the job well, enviro-friendly & CHEAP! The amazing thing was, after beadblasted some parts, and put 'em in the tank, man, you could literally see the "dust" being 'vibirated off' the parts in the water.... oh, the best...we wanted to save these hard to find oil coolers off from the 356 Carreras and I fabricated some plumbing to hook up a solution pump (off from the SK parts washer tank) to the cooler and use parts washer solution to pump in and out of the cooler with the (cooler) unit itself dunked in the ultrasonic tank....man, it was like a friggin CESSPOOL coming out of the cooler!!!! Unbelieveable!!! And it was good to know of these coolers being so clean that I would draw my hot drink thru the damn thing.... Brian: aah, now I see how you got your gearbox guts cleaned....expecially after beadblasted the box case...(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) now, I gotta get one of these sonic thingy for myself!!! (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Randal |
Feb 7 2005, 09:19 AM
I want something around to clean dirty engine parts, like engine tin, or suspension stuff.
So the best way to find one is to look in the want ads for used industrial equipment? Guess no one makes an affordable unit for home use. And Britain, I'l take you up on the offer. |
mightyohm |
Feb 7 2005, 11:13 AM
To clean stuff all you really need is a regular old parts washer.
Harbor Freight has a large one that looks decent and you can get a small one at Kragen for ~$30. |
bondo |
Feb 7 2005, 11:22 AM
Hmm, I wonder if I could add an ultrasonic peizo dealie to the underside of my parts washer... that would be awesome (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 29th May 2024 - 12:01 AM |
