I want to add a mechanical oil gauge, Who's done this before |
PanelBilly |
Feb 5 2015, 11:02 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'd like to have am accurate gauge right on the case of the /6 so I can keep an eye on the oil when I do the break-in. I've seen these on 911 and they face the back of the car to make it easy to read. I figure on the 914, it should face up. Anyone here installed one?
stugray |
Feb 5 2015, 11:23 PM
Here's mine:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1423200237.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1423200276.1.jpg) It uses a grease gun hose, a dual pressure sender, and a mechanical pressure gauge. |
Feb 6 2015, 08:35 AM
On the four, as stu posts, you can use a pain ball gun line, or a grease gun line to relocate the gauge, but you still would need to attach the stock idiot light sensor or it stays on....plus it all needs to be grounded to the stock sensor to work.
Rich |
GeorgeRud |
Feb 6 2015, 08:43 AM
Nice installation.
aircooledtechguy |
Feb 6 2015, 09:40 AM
Autometer makes a nice dampened, fluid filled gauge that is pretty small (around 1.5") that works great. I have one on my fuel pressure loop in the Squareback but it can also be used for oil too. I bought mine from www.speedmartinc.com for $40. Worth every penny.
VDO sells an inexpensive non-dampened gauge too. What a POS!! I recommend against a non-dampened gauge. Motor vibration will kill it in a couple months of driving. |
stugray |
Feb 6 2015, 03:05 PM
Nice installation. Thanks! The gauge is from an accusump. It is actually meant to go on the air side of the piston in the accusump, but works just fine as is (probably have an air bubble anyway). And on the website, they dont say it is NOT for direct measurement of oil pressure. https://www.cantonracingproducts.com/produc...AUGE-0-160-PSI/ |
Harpo |
Feb 6 2015, 04:23 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Sturay do you have a sketch of your clamp holding the "T" in place?
Thanks David |
stugray |
Feb 6 2015, 04:55 PM
QUOTE Sturay do you have a sketch of your clamp holding the "T" in place? No, but the lower piece is just a 1" U-channel. The upper is either 1" angle or another piece of U-channel with a leg cut off. I put some rubber shims under it to try to reduce the vibration. No idea if it helps. |
76-914 |
Feb 6 2015, 05:00 PM
Why not install one in the cockpit? It's nice to monitor one's oil pressure. Never have trusted elec sending units for oil pressure.
TargaToy |
Feb 6 2015, 06:35 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Mueller |
Feb 6 2015, 06:41 PM
Why not install one in the cockpit? It's nice to monitor one's oil pressure. Never have trusted elec sending units for oil pressure. Got to be careful, do you want hot oil spraying on you in case of a leak? I think there is a kit that has an isolator that you run in between the gauge and the oil line. |
sixnotfour |
Feb 6 2015, 06:57 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I know you have a six ,so its easy..1/8 pipe thread gauge on end...
PanelBilly |
Feb 7 2015, 05:49 PM
I'll ad a triple gauge later, Just want something on the engine for now before I try to start it up. Figure its easier to install while the block is out of the car.
Not alot of room to work. Pelican said to put in this unit, but I don't think I'll be able to read the gauge since it will face the firewall Here's how much space I have to deal with. |
stugray |
Feb 7 2015, 06:47 PM
That sender unit is likely 1/8" NPT (cant see the bottom)
If you remove that you could put in a tee or a grease-gun hose to relocate the sender with the gauge. |
sixnotfour |
Feb 7 2015, 07:09 PM
Billy wrong spot... There is a port next to the breather on a six way easier..
Usually there is a idiot light sender there.. |
PanelBilly |
Feb 7 2015, 07:58 PM
Ok that makes more sense
914bub |
Feb 7 2015, 08:20 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Id want one in the cockpit too. It's great to know your oil pressure at idle or even reving under no load but you'll care the most when your pushing your car through the twisties
PanelBilly |
Feb 7 2015, 11:09 PM
I'm planning to add a triple gauge but that may take a while. In the mean time, I'd like to be starting the engine
Mark Henry |
Feb 8 2015, 07:24 AM
Billy wrong spot... There is a port next to the breather on a six way easier.. Usually there is a idiot light sender there.. Id want one in the cockpit too. It's great to know your oil pressure at idle or even reving under no load but you'll care the most when your pushing your car through the twisties Use the grease gun whip, add a T in the line and keep the idiot light as well. Idiot light is very important to keep. One thing about Stugary's set up I don't like is if he's using the VDO sender for the idiot light. The VDO combo sender is known to be a very slow crap sender. It lights up after your engine is wiped out. |
stugray |
Feb 8 2015, 04:07 PM
Use the grease gun whip, add a T in the line and keep the idiot light as well. Idiot light is very important to keep. One thing about Stugary's set up I don't like is if he's using the VDO sender for the idiot light. The VDO combo sender is known to be a very slow crap sender. It lights up after your engine is wiped out. (IMG:style_emoticons/default/agree.gif) I installed the mech gauge because I had never had this car running ,ever, so I didnt want to trust any electrical when I first cranked the engine for cam break-in. I intended to swap out the gauge for the stock idiot pressure switch, but havent done so yet. I have a backup though. My datalogger reads all of the engine vitals and will turn on the "System idiot light" (Giant LED Trailer tail light!) on the dash if the pressure drops below a programmable value (same with oil temp, CHT, & EGTs) |
Lo-Fi Version | Time is now: 16th May 2024 - 04:13 AM |
