so where is the leak?, Plus another question about the Flywheel. |
malcolm2 |
Feb 6 2015, 05:52 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
My Tranz is at Dr. Evil's and I wanted to see if I could find a small leak that I see is coming out at the btm of the tranz/engine joint. Seams to be a small weep notch there.
I figured I would see it, but I don't, everything is pretty dry. You can see the burnt seam goo I used from Type4 store.com. And the galley plugs are very clean. The cam plug is dry too. when I pulled the flywheel oil spilled out of the open part main seal, I fIgured that was normal, right? I see what probably is clutch dust on the upper vertical tin. Any ideas on the leak? Should I change the seal while I have all apart. It only has about 7000 miles on it. So does that leave the tranz and the source? I did not look closely at it before I shipped it off. But it had a new seal in it too. Let me know if someone whats a close up picture of something. |
Feb 6 2015, 06:57 PM
If it's not the cam plug, I would change the RMS while you have it out.
Make sure Mike changes the front seal on the tranny. Rich |
Feb 6 2015, 09:16 PM
Gear oil smells much worse than engine oil. See if you can smell sulfur on the leak's residue.
--DD |
malcolm2 |
Feb 9 2015, 06:09 PM
just curious, anyone seen these BLACK spots on a 7000 mile flywheel?
I had it turned in 2012 as you can see.... should be Tenn "CLUTCH". (IMG:style_emoticons/default/blink.gif) The measurements that I can measure are still withing the NEW range. I remember about 1000 miles ago, I was backing up a driveway into the turnaround and had a ruff time off it.... Clutch wise. Steep driveway kinda thing. Other than that I have had no significant events that would make me think this happened. |
Feb 9 2015, 06:27 PM
It's measels, have you been vaccinated?
rjames |
Feb 10 2015, 11:14 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I don't see anything in the pic that looks like an oil leak, but it's hard to tell from the pics and without seeing it in person. As others have said, verify whether it's oil or trans fluid.
IMHO If the rear main seal isn't leaking and you only have 7k miles on it there's no need to change it. Re flywheel marks: What does the clutch disk look like? Additional things to check: crankshaft end play clutch fork end play ( Unfortunately, clutch and tranny need to be reinstalled to check this. ) |
Bulldog9 |
Feb 10 2015, 01:45 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
If not the rear main seal or other parts, what about that little o ring on the flywheel?
malcolm2 |
Feb 10 2015, 02:19 PM
DRPHIL914 |
Feb 10 2015, 02:21 PM
i went thru this last year and after rebuilding the trasmission and remounting it i found out the RMS was leaking so i had to again pull the trans and do the RMS. But whil i was in there my mechanic suggested using his meter to check for crankshaft endplay. good thing i did because it was out of spec , so the proper thickness of shimms were put in, new RMS and the flywheel remounted and it is back in spec. I actually replaced my flywheel and did the clutch, installed a new pressure plate and clutch disc as mine was a mess from all the oil.
- just make sure you check that end play and just do the RMS while you are there. . |
malcolm2 |
Feb 11 2015, 08:17 AM
Re flywheel marks: What does the clutch disk look like? Pictures of the 7000 mile clutch. If you look closely, you can see a film of oil radiating out from the center. Especially in the close up...the word "GERMANY" is darker. Is it normal to have alittle oil on that plate? Also, I found a NIB tranz shaft seal in my parts tub, so that tells me that I did not replace the seal in 2013 when I started driving. I remember thinking it would be difficult to do without the shaft being out, so I left the old one in. |
ndfrigi |
Feb 11 2015, 01:20 PM
I just removed yesterday my pressure plate and disc on my 71 1.7. and this week trying to remove also same parts from my 75 1.8 FI.
Both 71 and 75 has the same worn on the plate and I believe usual wear and tear from the throw out bearing. Well on the 75 this is the first time I removed it since I bought the car last 2011 and seated on a driveway for 8 years as non-op from the previous owner. On the 71 looks newly replaced from the previous owner since he bought it last 3 years ago before I bought it last september. The 75 1.8 has minor leak everytime I drive the car I will get a few drops from my garage floor and my guess it just need Flywheel seal/Rear main seal. The 71 1.7 has a lot of dirt inside the flywheel but the middle area of the flywheel seems to be clean. I think the oil leak and dirt comes from the valve cover since the heat exchanger has a lot of oil and dirt and maybe the oil is just flying all over the transmission. 71 1.7 75 1.8 |
ndfrigi |
Feb 11 2015, 01:22 PM
stugray |
Feb 11 2015, 01:39 PM
just curious, anyone seen these BLACK spots on a 7000 mile flywheel? I had it turned in 2012 as you can see.... should be Tenn "CLUTCH". (IMG:style_emoticons/default/blink.gif) The measurements that I can measure are still withing the NEW range. I remember about 1000 miles ago, I was backing up a driveway into the turnaround and had a ruff time off it.... Clutch wise. Steep driveway kinda thing. Other than that I have had no significant events that would make me think this happened. Those look like rust spots from the rivets that hold the clutch disk together. Look at some of the pics further down from your post. (IMG:http://www.914world.com/bbs2/uploads/post-13139-1423663923.jpg) See how the rivets are all in the center section of the FW right where your "measels" are? |
malcolm2 |
Feb 11 2015, 02:08 PM
Those look like rust spots from the rivets that hold the clutch disk together. Look at some of the pics further down from your post. (IMG:http://www.914world.com/bbs2/uploads/post-13139-1423663923.jpg) See how the rivets are all in the center section of the FW right where your "measels" are? I figured the rivets maybe, but I wonder if they are burns or for lack of a better term, cold spots? But they don't match up 1 to 1. on the clutch there are 2 rivets and a space. On the FW there are places with 4 or 5 spots in a row, equally spaced. Like I said, I remember one problem backing up a steep driveway where it felt like the acted up. Also, mentioned that I was just curious if anyone had seen the spots before. I am certainly not going to do anything about it. (IMG:style_emoticons/default/driving-girl.gif) Seemed odd. (IMG:style_emoticons/default/confused24.gif) |
914Mels |
Feb 11 2015, 03:40 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Look like hot spots to me, the metal actually gets hot enough to change structure and makes a spot like that. They are real common on brake drums and brake rotors that have been overheated. If you have the flywheel resurfaced with a grinding wheel, it will get rid of them for a time but the change to the metal goes pretty deep and they will "pop" back up down the road.
Lo-Fi Version | Time is now: 15th May 2024 - 04:19 PM |
