What battery are you using? |
GaroldShaffer |
Feb 8 2015, 08:39 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I don't have pictures (will add them tomorrow), but the PO of Brutus has a small garden style battery up in the front trunk. When fully charged it has just enough power to barely crank the engine.
I would like to find something better along that same size. What are you guys using? |
Racing916 |
Feb 8 2015, 10:58 PM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
odyssey pc680. Keep it on a trickle charger at home. Knock on wood has been a great battery.
brant |
Feb 8 2015, 11:02 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The size of the battery cable can matter for front trunks
Woody |
Feb 9 2015, 07:31 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Jetsetsurfshop |
Feb 9 2015, 02:38 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
This has worked good for me. It's been a bit since I installed it but I did run a larger cable.
campbellcj |
Feb 9 2015, 10:34 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
PC680 for me as well - very satisfied. It is in the stock location bolted-down on its side via the aluminum jacket/bracket.
stownsen914 |
Feb 10 2015, 04:09 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I use the ones sold by Baker Precision. I forget the designation, but it weighs about 12 lbs. At a little over $100, it's a pretty decent deal. I've been using their batteries for years with good luck.
Randal |
Feb 14 2015, 11:20 PM
Laugh, but Interstate has powerful, cheap and lightweight batteries. My current set up is like 12lbs and has 650 cranking amps. My motor is 12.5 to 1.
stownsen914 |
Feb 17 2015, 03:32 PM
Randal |
Feb 18 2015, 09:16 AM
Laugh, but Interstate has powerful, cheap and lightweight batteries. My current set up is like 12lbs and has 650 cranking amps. My motor is 12.5 to 1. Interesting. Are they gel cell batteries by chance? Will have to check, not sure. |
914forme |
Feb 18 2015, 10:38 AM
Interstate Gel, 12.3 lbs, and can be had at local supplier. Turned the 2.0L over for several years. Have not tried it with the Subaru yet.
R8CERX |
Feb 18 2015, 10:47 AM
2014 New year resolution: To get along with Woody... Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California |
Interstate Gel, 12.3 lbs, and can be had at local supplier. Turned the 2.0L over for several years. Have not tried it with the Subaru yet. Curious I read on the trickle charges that you can't use them on gel cells batteries I have a normal size battery on my six, and I am afraid to hook the harbor freight cheap trickle charger just because of the warning Any advise on what trickle charger will work? And what is the danger of using the cheap harbor freight charger? I am thinking that is the same circuitry as the more expensive one.... (IMG:style_emoticons/default/confused24.gif) |
mskala |
Feb 18 2015, 01:31 PM
Any advise on what trickle charger will work? And what is the danger of using the cheap harbor freight charger? I am thinking that is the same circuitry as the more expensive one.... (IMG:style_emoticons/default/confused24.gif) I've been using Odyssey PC680 for about 10 years. Got a new one after 8 years even though it showed no signs of going bad. I have never used a trickle charger on it. In a 914 when you turn it off there should be no drain unless you have a clock or some aftermarket gear. Batteries will self-discharge but I've not found it to be significant for the odyssey. Only in first start of spring if it's still really cold do I need to add jumper cables, since it takes about 10 tries to really get the engine going. |
R8CERX |
Feb 18 2015, 01:53 PM
Any advise on what trickle charger will work? And what is the danger of using the cheap harbor freight charger? I am thinking that is the same circuitry as the more expensive one.... (IMG:style_emoticons/default/confused24.gif) I've been using Odyssey PC680 for about 10 years. Got a new one after 8 years even though it showed no signs of going bad. I have never used a trickle charger on it. In a 914 when you turn it off there should be no drain unless you have a clock or some aftermarket gear. Batteries will self-discharge but I've not found it to be significant for the odyssey. Only in first start of spring if it's still really cold do I need to add jumper cables, since it takes about 10 tries to really get the engine going. Txt for reply Still, I have gel battery now; can I use the trickle charger on it? Why is it not advised by the trickle charger manufacturer? Danger of fire while in garage? |
914forme |
Feb 21 2015, 06:02 PM
On my interstate I used this
Mer of fact I use them on all my toys, 914, Miata, Tractor, and Boat. Works just fine, haven't burn't down my shop yet. |
914forme |
Feb 21 2015, 06:07 PM
duplicate post
GaroldShaffer |
Feb 21 2015, 07:21 PM
I ended up going with the Baker Precision mainly because its measurements fit the framework that the old battery was in.
PlaysWithCars |
Mar 12 2015, 09:26 PM
Senior Member Group: Members Posts: 523 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Odyssey PC680 for me as we'll. I use a BatteryMinder brand charger that has selectable charging profiles for for gel, flooded, and AGM batteries. Also when it's in trickle mode it has a desulfation feature that really extends battery life.
Johny Blackstain |
Mar 15 2015, 09:45 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Anyone know of a US source for DETA batteries?
earossi |
Mar 31 2015, 06:55 AM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Any advise on what trickle charger will work? And what is the danger of using the cheap harbor freight charger? I am thinking that is the same circuitry as the more expensive one.... (IMG:style_emoticons/default/confused24.gif) I've been using Odyssey PC680 for about 10 years. Got a new one after 8 years even though it showed no signs of going bad. I have never used a trickle charger on it. In a 914 when you turn it off there should be no drain unless you have a clock or some aftermarket gear. Batteries will self-discharge but I've not found it to be significant for the odyssey. Only in first start of spring if it's still really cold do I need to add jumper cables, since it takes about 10 tries to really get the engine going. Txt for reply Still, I have gel battery now; can I use the trickle charger on it? Why is it not advised by the trickle charger manufacturer? Danger of fire while in garage? I'm trying to recall from memory, the issue with using a regular trickle charger on a GEL battery. I think it has to do with the fact that the GEL's drop to very low voltages when they discharge, and a standard charger will not re-charge them. Not certain that is correct......however, I do remember that the way to use a standard charger to re-charge a GEL is to hook a good battery in parallel with the GEL and then use the charger on the parallel connected batteries. But, to answer your question, there are chargers and trickle chargers out there that have a GEL setting. I have a CEK that I use on my Optima that works fine. Has a switch for GEL batteries on it. Unfortunately, a little more expensive than a Harbor Freight charger. I think I paid about $60 for the CEK. |
Lo-Fi Version | Time is now: 28th April 2024 - 02:20 PM |
