6 heater box color ? |
scotty b |
Feb 10 2015, 03:39 PM
Trying to work out some of Cairo's smaller stuff. While getting a bunch of parts together to strip and re zinc, I noticed a shiny spot on his flapper boxes. It appears they were originally silver zinc, not painted ? Is this correct ? I know 911's were red/orange. I have the correct paint for them, and assumed 914-6 would have either been black, grey, or the same orange as the 911 since they went through the same plant. But I never would have expected them to be silver zinc'ed (IMG:style_emoticons/default/confused24.gif) Or were Michaels put on as bare steel (IMG:style_emoticons/default/blink.gif)
FWIW I see NO traces of any paint anywhere, and the raw metal that is visible is definitely not a sandblasted finish as if someone stripped them and didn't recoat. It is nice shiny metal with the press forming marks still on it Attached image(s) |
Feb 10 2015, 04:52 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Maybe they were replacements for the origional set?
914Sixer |
Feb 11 2015, 08:44 PM
914 Guru Group: Members Posts: 8,875 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
OEM were black.
porbmw |
Feb 12 2015, 12:24 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Johny Blackstain |
Feb 12 2015, 03:13 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Yep, semi gloss black is the way I remember them. Only shiny parts were the linkage the hinge pin.
rgalla9146 |
Mar 2 2015, 09:07 PM
Scotty
One NOS heat exchanger and six, 6 cyl. flapper boxes say "grey" 4 cyl. flappers were black. Rory Attached thumbnail(s) |
aturboman |
Mar 2 2015, 09:37 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
Indeed grey as Rory says, I too have had NOS ones.
scotty b |
Mar 2 2015, 09:42 PM
awesome. thanks guys (IMG:style_emoticons/default/first.gif)
Cairo94507 |
Mar 6 2015, 08:33 AM
Michael Group: Members Posts: 9,726 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Can they be powder coated and still operate correctly? BTW, I am pretty sure they are original to the car.
scotty b |
Mar 7 2015, 07:18 AM
Can they be powder coated and still operate correctly? BTW, I am pretty sure they are original to the car. I wouldn't. I'll glass bead them bare, epoxy prime and use an industrial grey on top. It'll be almost as good as powder without the mil build and possible issue of getting into the pin location keeping it form pivoting |
Cairo94507 |
Mar 8 2015, 07:33 AM
I kind of figured powder coating would be to thick. Sounds good.
Peashooter |
Jul 24 2015, 07:14 AM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
Not sure about the gray for six boxes. I had a NOS set I put on my car and they were semi-gloss or satin black. Still had the factory part stickers on them. Heat exchangers were gray.
Perry Kiehl Clone |
Jul 24 2015, 08:18 AM
Unregistered |
I used a high temp silver gray from Eastwood that looked good. Not concours perfect though.
Pat Garvey |
Jul 24 2015, 05:48 PM
Not sure about the gray for six boxes. I had a NOS set I put on my car and they were semi-gloss or satin black. Still had the factory part stickers on them. Heat exchangers were gray. Satin black, like on many parts down under, is correct. Someone got to them before you! |
Lo-Fi Version | Time is now: 4th May 2024 - 11:42 PM |
