Oil drip at the pressure bypass |
malcolm2 |
Feb 11 2015, 02:39 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
The large ORANGE screw next to the oil filter is ever so slowly leaking. It has a washer but is there anything else I can do to stop the leak. It is tough to know how tight to get it, since it is just a slot vs a bolt head that I could get a socket on and torque it. I suppose I could make a tool to go in the torque wrench.
914Mels |
Feb 11 2015, 03:32 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
I would try a new gasket and put a thin line if RTV on the threads near the gasket end. This is one spot I don't think I have ever had leak on mine. I used a screwdriver socket on a 3/8" ratchet to tighten it down.
Java2570 |
Feb 11 2015, 05:05 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I'd replace it with one of these new ones....they have a hex instead of the slot.
http://type4store.com/products/oiling-syst...lief-screw.html |
jim_hoyland |
Feb 11 2015, 06:18 PM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'd replace it with one of these new ones....they have a hex instead of the slot. http://type4store.com/products/oiling-syst...lief-screw.html The store has a $50 minimum and wanted to ship that one part for $20... (IMG:style_emoticons/default/sad.gif) Any other alternatives ? Is there a generic screw that could work ?? |
Java2570 |
Feb 12 2015, 07:13 AM
I'd replace it with one of these new ones....they have a hex instead of the slot. http://type4store.com/products/oiling-syst...lief-screw.html The store has a $50 minimum and wanted to ship that one part for $20... (IMG:style_emoticons/default/sad.gif) Any other alternatives ? Is there a generic screw that could work ?? Jim, here is another alternative from Aircooled.net....I forgot about Type 4 store's shipping requirements. http://vwparts.aircooled.net/Allen-Relief-...113-115-431.htm |
malcolm2 |
Feb 12 2015, 10:27 AM
I might buy one of the aircooled units. I emailed and asked them if theirs has the nub for the spring and if they sell washers.
I read a how-to somewhere that said to use a large screw driver like a chisel and tap the outside edge of the slot to tighten it up. How much oil will come out if I take it off with the case full? |
Java2570 |
Feb 12 2015, 11:33 AM
The large screwdriver idea does work to tighten it but it is easy to bugger the slot up.
Only a small amount of oil comes out.....when I installed my pressure block off from Tangerine, only about a teaspoon came out of mine. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:03 AM |
