malcolm2
Feb 11 2015, 02:39 PM
The large ORANGE screw next to the oil filter is ever so slowly leaking. It has a washer but is there anything else I can do to stop the leak. It is tough to know how tight to get it, since it is just a slot vs a bolt head that I could get a socket on and torque it. I suppose I could make a tool to go in the torque wrench.
914Mels
Feb 11 2015, 03:32 PM
I would try a new gasket and put a thin line if RTV on the threads near the gasket end. This is one spot I don't think I have ever had leak on mine. I used a screwdriver socket on a 3/8" ratchet to tighten it down.
Java2570
Feb 11 2015, 05:05 PM
I'd replace it with one of these new ones....they have a hex instead of the slot.
http://type4store.com/products/oiling-syst...lief-screw.html
jim_hoyland
Feb 11 2015, 06:18 PM
QUOTE(Java2570 @ Feb 11 2015, 03:05 PM)
http://type4store.com/products/oiling-syst...lief-screw.htmlThe store has a $50 minimum and wanted to ship that one part for $20...
Any other alternatives ? Is there a generic screw that could work ??
Java2570
Feb 12 2015, 07:13 AM
QUOTE(jim_hoyland @ Feb 11 2015, 07:18 PM)
Jim, here is another alternative from Aircooled.net....I forgot about Type 4 store's shipping requirements.
http://vwparts.aircooled.net/Allen-Relief-...113-115-431.htm
malcolm2
Feb 12 2015, 10:27 AM
I might buy one of the aircooled units. I emailed and asked them if theirs has the nub for the spring and if they sell washers.
I read a how-to somewhere that said to use a large screw driver like a chisel and tap the outside edge of the slot to tighten it up.
How much oil will come out if I take it off with the case full?
Java2570
Feb 12 2015, 11:33 AM
The large screwdriver idea does work to tighten it but it is easy to bugger the slot up.
Only a small amount of oil comes out.....when I installed my pressure block off from Tangerine, only about a teaspoon came out of mine.
