Rise from the ashes take 2, It looks like I have some work to do |
Phoenix914 |
Feb 13 2015, 11:43 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
My car has been sitting for too long. It's time to get it back in driving shape.
While assessing the condition of the engine, I found that the head on the driver's side has some issues to address. Here is the hardware that was holding the intake to the head: I know, right? We have seen this before. Yes, those are threads that came out next to the threaded rod/nut combo on the left. It looks like I have to drop the engine and pull that head. Question: Can anyone recommend a good machine shop in Central Florida to fix the head put the studs back in? |
Phoenix914 |
Apr 15 2015, 09:07 AM
I think my confusion stems from the unusual mounting location of the valve. It's usually shown next to the MPS in diagrams. I will be sure to put it there when everything goes back together.
BeatNavy |
Apr 15 2015, 09:41 AM
I think my confusion stems from the unusual mounting location of the valve. It's usually shown next to the MPS in diagrams. I will be sure to put it there when everything goes back together. Yeah, what's that decel valve doing up on the fan shroud? I've never seen it there. I assume it's always by the battery and MPS. I JUST got through going through a similar exercise: installed new engine (2056), refreshed tranny (for conversion to side shift), and new Triad exhaust. I completely cleaned up the engine bay (toothbrush and paint stripper, what fun!) and welded in a new battery tray and engine lid hinge. I cleaned up the engine (powder coated everything) and serviced as much as I could. It's turned out very well, but I spent several weeks planning it out and acquiring parts. Another two weeks with it up on jackstands while I pulled the old engine and put everything new in. I felt the pressure because if this thing isn't running my wife doesn't have a car at home. I'm fairly exhausted right now and I'm hoping to just enjoy to driving it for a few weeks before tackling anything else major. Good luck with your efforts. The "while you're in there" or "while it's out" thing can really send your project off on different tangents and make it take longer, and cost much more, than you planned. |
Phoenix914 |
Apr 15 2015, 02:24 PM
Yeah, what's that decel valve doing up on the fan shroud? I've never seen it there. I assume it's always by the battery and MPS. I JUST got through going through a similar exercise: installed new engine (2056), refreshed tranny (for conversion to side shift), and new Triad exhaust. I completely cleaned up the engine bay (toothbrush and paint stripper, what fun!) and welded in a new battery tray and engine lid hinge. I cleaned up the engine (powder coated everything) and serviced as much as I could. It's turned out very well, but I spent several weeks planning it out and acquiring parts. Another two weeks with it up on jackstands while I pulled the old engine and put everything new in. I felt the pressure because if this thing isn't running my wife doesn't have a car at home. I'm fairly exhausted right now and I'm hoping to just enjoy to driving it for a few weeks before tackling anything else major. Good luck with your efforts. The "while you're in there" or "while it's out" thing can really send your project off on different tangents and make it take longer, and cost much more, than you planned. I remember following some of your progress. You made a lot of headway in a fairly short time. Nice job! Like many of us, I have to overcome some DAPO nonsense to get the car as right as possible. Not to blame the previous (original) owner of my car, because I know he didn't do any mechanical work himself... He actually really loved this car and did his best with it. I just found a component mismatch that may have to rectified. Of course the fact that the engine is a 2056 with a carb-friendly cam makes the D-jet unhappy, anyway. Here is what I found: ECU: 0 280 000 037 Correct for a '73 2.0 MPS: 0 280 100 043 NOT for a '73 2.0, but rather for a '74 with a -043 ECU CHT: 0 280 130 012 (I do have the 270 ohm resistor, too) Should be -017, but those are NLA What to do? Can this cobbled-together bunch of parts make my engine run correctly? Should I swap one or more, or simply run what I've got? The rebuild paperwork I have says 272 deg. cam, which may be a Web 86b or 86c? That's a pretty hot cam for a 2056, and with D-jet I can't expect the best performance out of it. Man, what a mismatched mess this engine is. Surprising that it runs at all... |
Lo-Fi Version | Time is now: 14th May 2024 - 07:09 PM |
