Rise from the ashes take 2, It looks like I have some work to do |
Phoenix914 |
Feb 13 2015, 11:43 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
My car has been sitting for too long. It's time to get it back in driving shape.
While assessing the condition of the engine, I found that the head on the driver's side has some issues to address. Here is the hardware that was holding the intake to the head: I know, right? We have seen this before. Yes, those are threads that came out next to the threaded rod/nut combo on the left. It looks like I have to drop the engine and pull that head. Question: Can anyone recommend a good machine shop in Central Florida to fix the head put the studs back in? |
Dave_Darling |
Sep 3 2016, 11:52 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The original ones used rivets. Don't know if that is stock or not, though. Just about all of them now use bolts, but you have to double- and triple-check for interference between the bolt heads and the oil pump, and maybe even parts of the case.
--DD |
Phoenix914 |
Sep 4 2016, 05:35 AM
The original ones used rivets. Don't know if that is stock or not, though. Just about all of them now use bolts, but you have to double- and triple-check for interference between the bolt heads and the oil pump, and maybe even parts of the case. --DD This engine is supposed to have a "272 deg cam," according to the rebuild receipt from 1988, and I'm trying to ID it. Is it possible they riveted the cam gear back onto a new camshaft? I've decided to have the cylinders honed and replace the rings & rod bearings. There's only about 40k miles on this rebuild, so if the rod bearings look decent, then I won't go any further right now. (going to assume the mains would be decent, too) I discovered a local machine shop yesterday that looks like they have a clean facility and modern equipment, so I plan to talk to them this week about doing some work for me on this engine. |
Lo-Fi Version | Time is now: 15th May 2024 - 07:27 AM |
