fresh air blower, she's toast |
jr91472 |
Feb 7 2005, 05:49 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Finally took out the fresh air blower and dis-assembled.....
jr91472 |
Feb 7 2005, 05:51 PM
took the motor apart and yuk!!!!
melted plastic....aren't there supposed to be magnets in here? see arrows anyone want to sell me a fresh air blower? oop, wrong forum. Attached image(s) |
Gint |
Feb 7 2005, 08:18 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
BTDT
Michael J |
Feb 7 2005, 09:21 PM
Welcome to 2007 Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
Yuk, I started trouble shooting my blower this weekend and only got to the point that it would not run when wired direct to the battery. Not good. Next weekend it comes out and hope it looks better than yours. Might be able to get mine rebuilt.
dmenche914 |
Feb 8 2005, 01:35 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
i played with swaping heat blower parts on one with failed bushings, sometime they changed the direction of rotation, so the squirl cage blower vanes were pointed the wrong way(spun backwards) It still put out air, but not much.
Often the fresh air blower up front fails, and burns up cuase it gets jammed with leaves and crapola coming from the cowl vent. If you run it jamed, it will overheat and melt. Once repaired, stick some aluminum window screen material under the cowl vents above the blower (spray paint it black) Do not use nylon window screen, it won't last long in the sun. The screen will prevent all but the smalled bugs a bits from entering your fan. It will last a lot longer that way. The later factory plastic screen with roughly 1/4 inch holes is much too course to stop pine needles, small leaves,a nd bugs from clogging your fan, and drain lines. Early cars did not even have this factory screen. Think aluminum bug screen. |
jr91472 |
Feb 8 2005, 02:21 PM
awsome idea (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) this fan has never worked since I have owned the car, but guaging by the melt down, I would say that is what happened here thanks again |
JmuRiz |
Feb 8 2005, 03:25 PM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Mine doesn't have that screen and was very much clogged with stuff when I took it apart. Figures it worked when I looked at the car and the whole 10 hour drive home...parked it and the 2nd time driving it didn't work. I like the window screen idea, looks better than the factory screen. Keep us up to date on this, I know a LOT of people have fresh air blowers that don't work. |
jr91472 |
Feb 8 2005, 05:27 PM
will do... Lawrence is bailing me out with the blower out of his parts car. With luck I will have it next week sometime. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) thanks all (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 07:45 AM |
