Which Break in Oil? With Raby Cam & Lifters., Brad Penn or Joe Gibbs. |
tach |
Feb 23 2015, 09:23 AM
Member Group: Members Posts: 79 Joined: 6-November 09 From: Minnesota Member No.: 11,016 Region Association: Upper MidWest |
Which is the preferred choice for a first 30 minute start on a completely new rebuilt engine with a Raby cam and lifters? Penn or Gibbs break in oil. Mineral oil or synthetic?
Bradd Penn, SAE 30W Grade1 Pen-7120 . Joe Gibbs, 5-30 BR30. or BR10-40. http://penngrade1.com/Products/High-Perfor...eak-In-Oil.aspx http://www.drivenracingoil.com/dro/br30-br...-oil-15781html/ |
maf914 |
Feb 27 2015, 03:43 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
If Joe Gibb's Driven oil is now preferred, which oil is recommended for street use with a type 4 engine: DT40 5W-40, DT50 15W-50, or HR 10W-40, HR 15W-50? I assume 15W-50 for summer, but which type, DT or HR?
http://lnengineering.com/products/lubrican...oducts.html?p=2 |
Jake Raby |
Feb 27 2015, 10:09 PM
If Joe Gibb's Driven oil is now preferred, which oil is recommended for street use with a type 4 engine: DT40 5W-40, DT50 15W-50, or HR 10W-40, HR 15W-50? I assume 15W-50 for summer, but which type, DT or HR? http://lnengineering.com/products/lubrican...oducts.html?p=2 LS 30 for cold climate operation with temps less than 40F DT40 for mild cold, up to the low 70s DT50 for everything hotter than that. Internal clearances and oil pump selection do impact this. The HR oils are fine if you want a conventional. I use them after break in oils, before going synthetic. |
Lo-Fi Version | Time is now: 28th May 2024 - 01:40 PM |
