Subaru Engine Swap, It is now the 1971 Ivory Car |
AndyB |
Feb 27 2015, 12:39 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
Mike Bellis |
Feb 27 2015, 07:08 PM
Most likely you could use the radiator from the donor car and build a shroud. Anything is possible. The Scirocco radiator is small and aluminum units are very efficient.
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
AndyB |
Feb 27 2015, 07:10 PM
Most likely you could use the radiator from the donor car and build a shroud. Anything is possible. The Scirocco radiator is small and aluminum units are very efficient. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) I knew you would weigh in Mike thanks. And are we talking origional scirocco? |
Mike Bellis |
Feb 27 2015, 07:30 PM
I knew you would weigh in Mike thanks. And are we talking origional scirocco? No. I'm talking about a "Scirocco" radiator like you would find at Summit Racing or Jegs. They are about the smallest unit on the market and would be great for a modest Subi. The key in any radiator is controlling air flow. |
Lo-Fi Version | Time is now: 12th May 2024 - 09:50 PM |
