Subaru Engine Swap, It is now the 1971 Ivory Car |
AndyB |
Feb 27 2015, 12:39 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
mgp4591 |
Apr 3 2015, 10:00 PM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I was wondering if all the twists and turns in the coolant hoses for the different builds have affected the head pressure on the stock water pump making it work harder and maybe less efficient? If the hoses are run with fewer directional changes is that going to help some cooling issues? You still want a high point where you fill it and bleed your system and there are several options for that location. That being said, the center console on my car is rotted in some places over an inch off my equally rotted floor so I'm installing a section of rectangular tubing in place of the main console section that I plan to run my hoses through then weld my remaining section of unmolested console on top of. Should give me a straighter path for coolant flow and if properly insulated should work well for my purposes. Still plan on the brake lines and throttle cable through the remaining console section, shift cable too for the automatic. (GASP!)
Thoughts? |
Lo-Fi Version | Time is now: 12th May 2024 - 09:07 PM |
