Subaru Engine Swap, It is now the 1971 Ivory Car |
AndyB |
Feb 27 2015, 12:39 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
mgp4591 |
Apr 3 2015, 10:38 PM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I've already pulled the tail section from a 2wd 4EAT trans and bolted it on- it makes the trans about 6 to 8" shorter and looks like it will fit. The gearing for that trans in the SVX (3:55) was poorly matched to the AWD setup with a 3700 lb curb weight. That's about the only thing that made those fail prematurely- they're used in Nissan Pathfinders all the time with little issue, but they are geared properly for the weight of that vehicle. With only 2300 lbs to drive, I think it should work just fine even tho it'll be a tad tail heavy but in weight proportionate compared to some other mid engined cars. I eventually want to go with a manual trans but without the 4:88 final drive which limits the top speed to about 120. It's not so much the top speed I'm looking for- it's the low cruising rpm and resultant mileage I'm looking for. Well okay. the top speed would be cool too but not until the chassis and brakes are fully sorted. I also have the piggyback TCU that changes the shift points for better performance. With the overall weight of my car, the engine power and the gearing the car should jump and roll pretty well... I think. (IMG:style_emoticons/default/idea.gif)
Lo-Fi Version | Time is now: 13th May 2024 - 01:48 AM |
