Subaru Engine Swap, It is now the 1971 Ivory Car |
AndyB |
Feb 27 2015, 12:39 PM
The Governor is watching me Group: Members Posts: 1,115 Joined: 10-April 10 From: Philadelphia New York Member No.: 11,595 Region Association: North East States |
So I am finally doing the Subaru drive train conversion. I picked up my donor car from a salvage auction for $200.00. Yes the entire car and yes it does drive and run. With that being said I am still looking to those more knowledgable in the Subaru arena. The car is a 2002 Impreza Outback Sport. It has a 2.5l in it and over 200k on the odometer. My plan is to tear the engine down and rebuild it a little more then stock. I have no intentions of dropping in a turbo, that's for another one. Who are some reliable sources for performance parts other then all the usuall Subaru upgrades that would be done on a Subaru. I am concerned about the cooling aspect of the engine. I would like to know what people are using for radiators. Thanks.
Chris H. |
Apr 3 2015, 10:22 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
You're thinking about doing an automatic trans? Not the Subaru AWD auto from the SVX right? It's too long and weighs a TON. The gearing is also very poorly matched to the engine. You'd probably want to find a 2WD Subie trans (pre-1997ish).
mgp4591 |
Apr 3 2015, 10:46 PM
914 Guru Group: Members Posts: 5,370 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
You're thinking about doing an automatic trans? Not the Subaru AWD auto from the SVX right? It's too long and weighs a TON. The gearing is also very poorly matched to the engine. You'd probably want to find a 2WD Subie trans (pre-1997ish). And it looks like all 2WD automatics from 92 on in all Subarus were 4EATs. I pulled my 2WD tail section from a 93 Impreza- it bolted right on to the SVX trans along with the internal shaft, gear and bearing that eliminates the electromagnetic AWD assembly. It was a high point of my day when I found the part and it fit, all for 40 bucks! |
Lo-Fi Version | Time is now: 12th May 2024 - 06:57 AM |
