What fluid for transmission, and how much? |
PanelBilly |
Feb 28 2015, 06:05 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'm out shopping with my wife and I'd like to pick up fluid for the transmission. What am I looking for ?
PanelBilly |
Feb 28 2015, 06:53 PM
How much for an empty case?
BeatNavy |
Feb 28 2015, 07:32 PM
Hank914 |
Mar 1 2015, 09:43 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
How much for an empty case? Capacity? In total 2.5 quarts, but because you can't drain it dry while it's still in the car you can only really get about 2 quarts into it. I have only ever filled it after draining it dry. So how does one go about checking the oil level? Open up the top plug and stick a finger in it? |
SLITS |
Mar 1 2015, 10:24 AM
How much for an empty case? Capacity? In total 2.5 quarts, but because you can't drain it dry while it's still in the car you can only really get about 2 quarts into it. I have only ever filled it after draining it dry. So how does one go about checking the oil level? Open up the top plug and stick a finger in it? Oil level is checked on level ground ... pull top plug ... oil level should be even with the bottom of the hole. I fill till some starts running out and put the plug back in. You can get a gallon of gear oil with a pump on it from your local FLAPS (or used to be able to). |
Lo-Fi Version | Time is now: 17th May 2024 - 02:15 AM |
