AN Adapters and fittings, Anywhere to pick this stuff up locally? |
boxsterfan |
Feb 28 2015, 10:36 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Need to some 6-AN to 3/8" (9.5mm) barbed and 6-AN to 5/16" (8mm) barbed fittings. I can find on the web, but was wondering if I can find this stuff locally?
Mostly, just trying to save on shipping. For example, I need this adapter from CBPerformance: http://www.cbperformance.com/ProductDetail...88&CartID=1 However, I also need these: 1. 45 degree 6-AN to 3/8" (9.5mm) barbed 2. 45 degree 6-AN to 5/16" (8mm) barbed But CBPerformance doesn't carry these. In fact, the only place I see item #2 (45 degree 6-AN to 5/16" (8mm) barbed) is on eBay and it ships from china. I'm looking to do a setup similar to this: http://www.914world.com/bbs2/index.php?sho...=241493&hl= except I am using FI so will have the return line (and thus the need for item #2 above. I could always buy an SS 9.5 to 8mm adapter from Tangerine, but I was just hoping to come right from the SS lines in the tunnel to the tank. Note: My fuel pump is being mounted on rear firewall (not original rear location). |
DBCooper |
Mar 1 2015, 09:39 AM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Online's best for selection and price, and probably overall best bet. As already mentioned, all those online companies have more stocking numbers than are published, so call to check them before anything else. If you need it RIGHT NOW try speed shops in your area, a good one will have a pretty good selection. Pretty good but not exhaustive, so you may waste some time chasing them around.
Lo-Fi Version | Time is now: 19th May 2024 - 10:21 AM |
