AN Adapters and fittings, Anywhere to pick this stuff up locally? |
boxsterfan |
Feb 28 2015, 10:36 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Need to some 6-AN to 3/8" (9.5mm) barbed and 6-AN to 5/16" (8mm) barbed fittings. I can find on the web, but was wondering if I can find this stuff locally?
Mostly, just trying to save on shipping. For example, I need this adapter from CBPerformance: http://www.cbperformance.com/ProductDetail...88&CartID=1 However, I also need these: 1. 45 degree 6-AN to 3/8" (9.5mm) barbed 2. 45 degree 6-AN to 5/16" (8mm) barbed But CBPerformance doesn't carry these. In fact, the only place I see item #2 (45 degree 6-AN to 5/16" (8mm) barbed) is on eBay and it ships from china. I'm looking to do a setup similar to this: http://www.914world.com/bbs2/index.php?sho...=241493&hl= except I am using FI so will have the return line (and thus the need for item #2 above. I could always buy an SS 9.5 to 8mm adapter from Tangerine, but I was just hoping to come right from the SS lines in the tunnel to the tank. Note: My fuel pump is being mounted on rear firewall (not original rear location). |
Mike Bellis |
Mar 1 2015, 09:07 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
This guy once got me a weird thread brake fitting. He has everything and can make you hoses too.
Source Tubes & Hoses 421 N Buchanan Cir Pacheco, CA 94553 |
Lo-Fi Version | Time is now: 19th May 2024 - 09:02 AM |
