Clutch Delrin pulley orientation?, What is the correct way to install this thing? |
Steve |
Mar 1 2015, 01:56 PM
914 Guru Group: Members Posts: 5,578 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
What is the correct orientation of the aftermarket delrin clutch pulley? To me option 2 looks correct. When I get a chance I will look at the cable orientation to see which one makes more sense. The lip on the delrin is thicker on one side versus stock.
Option 1 with ridge on outside Option 2 with ridge on the inside |
Harpo |
Mar 1 2015, 07:21 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I didn't notice a difference on mine when I install it. My assumption is that it was not made accurately. However as long as nothing is binding it maybe just fine. One way to confirm would be to drive it around the block then remove and examine the pulley and cable for wear
David |
Jeff Hail |
Mar 1 2015, 08:12 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
What is the correct orientation of the aftermarket delrin clutch pulley? To me option 2 looks correct. When I get a chance I will look at the cable orientation to see which one makes more sense. The lip on the delrin is thicker on one side versus stock. Option 1 with ridge on outside Option 2 with ridge on the inside #2 is Correct. The oem pulley has ridges on both sides. The grove is centered. The delrin has the ridge on one side. Its still centered because one side is thicker (the same as a narrower pulley with ridges on both sides). Need the ridge facing the carrier bracket otherwise it will rub when you tighten up the nut and not turn freely. Attached image(s) |
Steve |
Mar 1 2015, 08:46 PM
Awesome!! Thanks!!
Lo-Fi Version | Time is now: 6th May 2024 - 03:24 AM |
