Flat 8 ? I've seen pics of the Lind one, how about a running one here! |
Mueller |
Mar 4 2015, 06:01 PM
If VW made a flat 8 (IMG:style_emoticons/default/smile.gif)
Brazilian Flat 8 I know, not a Type IV, I would think it would be close enough to a Type I to be done the same way? |
r_towle |
Jan 29 2023, 04:47 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
@Mueller are you still on the board?
Did you find anyone making cases or cranks? I am close to starting up this project Mill and lathe here, just getting them hooked up. |
SirAndy |
Jan 29 2023, 05:00 PM
Resident German Group: Admin Posts: 41,640 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
@Mueller are you still on the board? Did you find anyone making cases or cranks? I am close to starting up this project Mill and lathe here, just getting them hooked up. I still think copying the original flat /12 design with the center supported crank could work for two stock /4 cranks welded together. You need to eliminate the tendency of the crank to want to bend in the center under torque. It was also bloody brilliant to run the fan in the center straight off gears on the crank. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.stuttcars.com-179-1675033228.1.jpeg) |
r_towle |
Jan 29 2023, 06:13 PM
@Mueller are you still on the board? Did you find anyone making cases or cranks? I am close to starting up this project Mill and lathe here, just getting them hooked up. I still think copying the original flat /12 design with the center supported crank could work for two stock /4 cranks welded together. You need to eliminate the tendency of the crank to want to bend in the center under torque. It was also bloody brilliant to run the fan in the center straight off gears on the crank. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.stuttcars.com-179-1675033228.1.jpeg) Two points, When cutting the case to do this, you are left with two main journals next to each other…I don’t think bending could happen at that point. The fan… I’m intending on a horizontal fan, and I found some high speed 90 degree transmission I can use from a pulley at the front to a shaft mounted fan. Now, I did see @Cairo post a new fan shroud on some other thread somewhere….I want to see who he got that from…make it a bit longer |
Lo-Fi Version | Time is now: 17th May 2024 - 06:08 PM |
