Intermediate shift rod, need one |
Randal |
Feb 11 2005, 03:43 PM
Anyone have one lying around?
If you do have to ask I'm going to blame Andy. |
ClayPerrine |
Feb 11 2005, 03:46 PM
Life's been good to me so far..... Group: Admin Posts: 15,512 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
"intermediate shift rod"?
What part do you mean? Internal to the transmission, or one of the external ones? |
Randal |
Feb 11 2005, 03:48 PM
The rod that runs from the engine compartment up to the shifter. The shifter has a cast piece and bolt that ties to it...
Feb 11 2005, 03:49 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i had fun with the (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) , that's all i have to say about it ... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Andy |
eeyore |
Feb 11 2005, 04:41 PM
I probably has one... lemme check tonight. All or part? I suspect the "...cast piece and bolt that ties to it..." only
Feb 11 2005, 04:52 PM
nope. he needs the *rod*, not the shifter part ... i had to saw off the rod at the rear coupler because the setscrew was stripped and didn't come out. and we didn't have much time, so out came the hacksaw. all he needs is the rod that goes between the shifter and the "behind the firewall" coupler. btw. we're talking sideshifter here ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
eeyore |
Feb 11 2005, 05:21 PM
OK.
Randal |
Feb 13 2005, 06:31 PM
Here is a picture for the side shifter rod. The dimensions are:
Overall the shaft is approx. 31" long. The tube diameter is approx. 3/4". The shaft on the shift assembly side is 16 5/8". This 1/2" shaft is welded to the larger 3/4" tube. The final 2" on the shaft has splines cut into it. Attached thumbnail(s) |
scotty b |
Feb 13 2005, 06:34 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Why not just weld it back together? Did he go nuts with the sawzall? (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif)
Mueller |
Feb 13 2005, 06:44 PM
if you need the part that attaches to the shifter and sit's inside the middle tunnel, I have one....
Feb 13 2005, 07:46 PM
yes, that's the rod in his picture ... inside the tunnel, from shifter to coupler right behind the firewall .. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Mueller |
Feb 13 2005, 07:52 PM
$10 work for you??
Feb 13 2005, 07:59 PM
don't ask me, as randal! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) i was just the one who cut it ... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) Andy |
Randal |
Feb 14 2005, 08:28 AM
Yes!. I'll PM you for directions. Thanks Mike. |
Mueller |
Feb 14 2005, 12:39 PM
good news/bad news
good= I've got the correct part for you.... bad= the hole for the "cone" set screw is tweaked, last time I had to repair one of these, I filled the hole with JB Weld, and inserted the correct set screw covered with a plastic sheet to form the correct female pattern. if you want to try this, you can just have the shift rod for free..... Attached image(s) |
Feb 14 2005, 03:31 PM
just weld it up ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Trekkor |
Feb 14 2005, 08:00 PM
Randal I will have one for you on Sunday.
Feed me and I will deliver it (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) KT |
Mueller |
Feb 14 2005, 08:06 PM
Randal is going to need it Trekkor...he's decided to pass on mine due to the damage....being a dedicated track/auto-x car, it is wiser to have a known good part than a part that has already been comprimised.
Trekkor |
Feb 14 2005, 08:20 PM
Remember the free 914 last year I gave away?
It's coming back home... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) KT Attached image(s) |
Mueller |
Feb 14 2005, 08:28 PM
is that a white interior??? look nice, but I could never have a car with such a light colored interior.....
Lo-Fi Version | Time is now: 6th June 2024 - 06:51 PM |
