Carb Issue, Spitting gas out of carb. |
X911IC |
Mar 17 2015, 07:42 PM
Member Group: Members Posts: 81 Joined: 17-June 13 From: California Member No.: 16,026 Region Association: Southern California |
Engine has Weber 44's. The venturi over #1 cylinder is spitting gas upon actuating the throttle. Seems as though there is positive pressure in venturi as opposed to vacuum, but have not tested with flow meter. Other venturis all seem to have a vacuum. Any thoughts what would cause this condition? My first thought was to check valve clearance to make sure they were shutting completely. Open to suggestions to diagnose the problem. Thanks in advance. Need to get this sorted prior to WCR!! Neil
Lo-Fi Version | Time is now: 17th May 2024 - 11:01 PM |
