QUOTE(colingreene @ Mar 17 2015, 08:31 PM)
The problem is the hole in the accel port needs to be plugged i think Ill have to check my notes to see what we did to fix it.
Mine was spitting fuel till we either plugged a hole or drilled a hole out larger.
where in ca are you? can you bring both carbs to me in Lake Forest?
Perfect! . I will PM with contact info, Thanks Neil
