Advice on Anti-Sway bar...., Looking for non-OEM. |
BuddyV |
Mar 20 2015, 08:57 AM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
I am building a car that will have a 2056, riding on stock steel wheels, narrow body. I've never been a racer or Autocrosser.... mostly spirited driving the 3-4 times a month I get to take out my cars for a ride to work or taking the LOOOOOONG way to the hardware store.
I would like to get a front anti-sway bar. I bought a stock one for my other car, and I do like it... but they are getting harder to find in good condition. I am interested in a new model. What's a good value out there that would give me the ride/performance quality in between a stocker and a full-out race-bred unit? ..... because I might try some lite AutoCross this year.... just for fun. Looking forward to your suggestions, and hope they are member vendors. |
ConeDodger |
Mar 20 2015, 09:28 AM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Tarret makes a very high quality bar with adjustability... (IMG:style_emoticons/default/driving.gif)
Mar 20 2015, 09:50 AM
Cheapest: Addco. Under-body type, not adjustable, less than ideal geometry. I wouldn't bother, personally.
Cheap: Weltmeister. The 19mm adjustable one should be perfectly adequate for your needs. If you were going on the track with any regularity, I'd suggest not using them, but for the street and some autoX they are fine. More expensive: Tarrett. Higher quality, higher price. Three styles, retro-RSR (discrete adjustment), standard (sliding adjustment), and blade-arm (twist the blade for adjustment, can be done from in the cockpit if you set it up for that). I can't seem to find Smart Racing Products sway bars any more. Those were evidently the next step up from Tarrett--I think. Elephant Racing seems to carry the Tarrett ones. Pelican shows the WM ones as not available, while Paragon shows the 19mm WM bar as available. Whatever you do, don't use the "no gas tank removal required" installation kits. They're pretty horrible. Pull the tank and do the job correctly. If you can weld, it's a good idea to weld in the nut plates that go around the through-body holes. --DD |
Mar 20 2015, 10:51 AM
Tarret makes a very high quality bar with adjustability... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) |
siverson |
Mar 20 2015, 11:35 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I agree and well worth the price upgrade from Weltmeister. I've replaced two Weltmeister bars with Tarrett.
-Steve Tarret makes a very high quality bar with adjustability... (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) |
screenguy914 |
Mar 20 2015, 12:13 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Sway bars are but one element needed for good handling. It is also the one mod. that affects ride harshness the most. Don't overdo it with sway bars
Think sway bars, torsion bars, shocks, proper alignment and corner balancing as overall objectives. Suggest some research for the best combination of each of the above elements for your personal driving objectives/conditions. Sherwood |
ConeDodger |
Mar 20 2015, 12:16 PM
Cheapest: Addco. Under-body type, not adjustable, less than ideal geometry. I wouldn't bother, personally. Cheap: Weltmeister. The 19mm adjustable one should be perfectly adequate for your needs. If you were going on the track with any regularity, I'd suggest not using them, but for the street and some autoX they are fine. More expensive: Tarrett. Higher quality, higher price. Three styles, retro-RSR (discrete adjustment), standard (sliding adjustment), and blade-arm (twist the blade for adjustment, can be done from in the cockpit if you set it up for that). I can't seem to find Smart Racing Products sway bars any more. Those were evidently the next step up from Tarrett--I think. Elephant Racing seems to carry the Tarrett ones. Pelican shows the WM ones as not available, while Paragon shows the 19mm WM bar as available. Whatever you do, don't use the "no gas tank removal required" installation kits. They're pretty horrible. Pull the tank and do the job correctly. If you can weld, it's a good idea to weld in the nut plates that go around the through-body holes. --DD If Elephant Racing is carrying Tarret, the OP can pick it up. They're located in San Jose... |
BuddyV |
Mar 20 2015, 02:05 PM
Yes, Elephant carries the Tarret.... and I can pick up in person.
Thank you all! (IMG:style_emoticons/default/pray.gif) |
Jeff Hail |
Mar 20 2015, 10:28 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Ira Ramin (Tarett) makes most of the above mentioned products except A & W.
Notice similarity in design. Many option to choose from (solid, hollow, retro). Ira is a stand up guy, eats and breathes Porsche. Everyone is marketing everyones products, its a small world. |
infraredcalvin |
Mar 21 2015, 03:31 AM
Distracted Member Group: Members Posts: 1,518 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
GPR had advertised a tarrett style (I assume it was a tarrett) in dark grey anodized and smaller bar. Maybe a group buy is in order???
toadman |
Mar 21 2015, 12:11 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Sway bars are but one element needed for good handling. It is also the one mod. that affects ride harshness the most. Don't overdo it with sway bars Think sway bars, torsion bars, shocks, proper alignment and corner balancing as overall objectives. Suggest some research for the best combination of each of the above elements for your personal driving objectives/conditions. Sherwood I agree with Sherwood. My car came to me with red Koni shocks and 140# springs on the rear and no sway bars. I added a sway bar and orange Koni Sport shocks on the front. When I am back on the road I will get a corner balance and proper alignment for autocross and the occasional drivers education event. |
Woody |
Mar 21 2015, 03:55 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Don't forget about this one. Chris at Tangerine sells this bar setup and it looks top notch. Very nice price too.
http://tangerineracing.com/antiswaybars.htm |
Lo-Fi Version | Time is now: 20th May 2024 - 08:15 PM |
