Drilling hubs for 5 lug, Any recommended shops in San Diego Area (NC SD?) |
Alphaogre |
Mar 20 2015, 10:13 AM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I am looking to get rid of my 5 lug conversion kit and have the hubs drilled out and studs pressed in. I live in North County near VW Paradise but they seemed to shy away from it and mentioned a shop called fat performance, but they are up in LA. Anyone know of any shops that they could recommend for this type of work in the north county or San Diego area?
Or should I just get my drill out and just eyeball it... haha (IMG:style_emoticons/default/biggrin.gif) |
bulitt |
Mar 20 2015, 02:25 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I am looking to get rid of my 5 lug conversion kit and have the hubs drilled out and studs pressed in. I live in North County near VW Paradise but they seemed to shy away from it and mentioned a shop called fat performance, but they are up in LA. Anyone know of any shops that they could recommend for this type of work in the north county or San Diego area? Or should I just get my drill out and just eyeball it... haha (IMG:style_emoticons/default/biggrin.gif) I think you are looking to have your 4 hole hubs drilled for 5 hole? Contact Eric Shea at PMB performance in Utah, or PM him on this forum. Few are better. |
colingreene |
Mar 20 2015, 09:54 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Fat is in orange county.
'73-914kid |
Mar 21 2015, 12:43 AM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Get ahold of Eric Shea. I tried to get FAT to do mine a couple of years back, and they wanted an insane amount of money to drill 5 freeking holes. Setting up a mill on a 365 degree table really isn't that tough, nor should it take all that long.
G e o r g e |
Mar 21 2015, 01:05 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
try Costa Mesa R & D. I have no idea on cost, but I'm sure they would do them.
Also Bruce Stone probably knows someone as well |
infraredcalvin |
Mar 21 2015, 03:10 AM
Distracted Member Group: Members Posts: 1,518 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I'd be interested in having 1 maybe 2 of my sets done as well, could be a better deal if a few sets were done. I'm not too far from SD, I'd be happy to coordinate with an Orange County shop.
colingreene |
Mar 21 2015, 11:43 AM
I could potentially do the work really. I just have to figure out what its worth to me.
Ethan, Fat is wildly over priced anymore. You should have seen the price they wanted for doing my heads. |
veekry9 |
Mar 21 2015, 08:42 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Well,if you have a proven ability to drill holes to a tolerance of +/-0.005 gdt squarely into an iron surface with or without a drill press.
The holes must meet a tolerance of +0.003/-.004 on diameter as the stud is retained by the press fit when driven in. Any deviation from those numbers and the stud will be stressed and may fail prematurely,they must match the wheel seats. Losing a wheel at speed is not cool in oncoming traffic,like losing a wing spar. (IMG:style_emoticons/default/bye1.gif) Sorta like driving a 914 with original hard brake lines,or even,gasp,flexlines.Normal replacement duty cycle.Due diligence. |
veekry9 |
Mar 21 2015, 09:07 PM
Fabricating a jig that locates on the original bp would make it possible to do the job with pilot bushings and drills.
Still need a press as the stud is a negative clearance,interference fit and must be driven squarely,a mere hammer allows too much chance of a stud seated at an angle. A block with a close fit hole on the stud would work to solve that.Use the correct studs,not cheapos,not all bolts are equal. A drill ground for drilling iron is paramount,not the same as steel. |
bdstone914 |
Mar 21 2015, 10:34 PM
It is not just drilling five holes. The back side needs to be faced off for the stud to fit flat. I have used FAT and they charged $90 for doing a pair with out studs. If you attempt it not where the two 6mm holes are for the screws. If you start on the wrong stud you will drill out one of the holes.
And the flanges are mild steel not iron. |
veekry9 |
Mar 21 2015, 10:43 PM
That's a good response,a bargain at that price. (IMG:style_emoticons/default/biggrin.gif)
Spoke |
Mar 22 2015, 06:08 AM
Jerry Group: Members Posts: 6,983 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had Eric Shea drill hubs for me. Didn't press fit; E suggested to do screw in. Worked out great. Don't have to surface the back of the hub and wouldn't have to remove the hubs if you wanted to change stud length.
Got the studs here: Race Studs.com |
Alphaogre |
Mar 22 2015, 09:55 PM
Thanks for the recommendations. If you do not press the studs in, then what keeps them from backing out? Red lock-tight? I would l like to run steel open ended lug nuts and not cap lugs nuts.
ndfrigi |
Mar 23 2015, 12:02 AM
Advanced Member Group: Members Posts: 2,929 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Here is my recent conversion from Eric's product but I got mine from bill1963 that he bought a few years ago but didn't use it since he bought 2 sets.
ThePaintedMan |
Mar 23 2015, 07:27 AM
I'd just send them to Eric as well.
It should be noted that the intended use for the car should be taken into account. If the hubs are drilled, there are several studs that will be going through *very* little steel. I have already seen one car (tooms351) with a 5-lug conversion that was pulling the studs through the hub after track use (and slicks). Eric will weld in reinforcements where necessary and do the job right. |
Alphaogre |
Mar 24 2015, 12:21 AM
I'd just send them to Eric as well. It should be noted that the intended use for the car should be taken into account. If the hubs are drilled, there are several studs that will be going through *very* little steel. I have already seen one car (tooms351) with a 5-lug conversion that was pulling the studs through the hub after track use (and slicks). Eric will weld in reinforcements where necessary and do the job right. That's a good point, I would be doing some track events, but not with slicks and a mighty 1.7 motor (IMG:style_emoticons/default/biggrin.gif) |
colingreene |
Mar 24 2015, 11:28 PM
I am a Aerospace engineer with a mill, my dad is a Aerospace engineer who also did his own and my friend with the mill is weirdly enough a Aerospace engineer. I figure i could handle it but, im sure you will get it taken care of.
oldschool |
Mar 25 2015, 01:53 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
I am a Aerospace engineer with a mill, my dad is a Aerospace engineer who also did his own and my friend with the mill is weirdly enough a Aerospace engineer. I figure i could handle it but, im sure you will get it taken care of. Hey Soylent green how much to drill mine (IMG:style_emoticons/default/rolleyes.gif) |
colingreene |
Mar 26 2015, 09:58 AM
Do you have spare hubs i can drill or do we have to pull the parts off your car?
Are we going to do thread in or press in? |
infraredcalvin |
Mar 26 2015, 10:31 PM
Where in so cal are you? I've got some alredy drilled for press in style you could use as a template.
Lo-Fi Version | Time is now: 20th May 2024 - 07:28 PM |
