Early 1.7 TPS GB for replacement board $25+shipping, IN in stock with directions |
Mikey914 |
Mar 20 2015, 04:33 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got the 1.7 Early 70-71 TPS boards done. Probably not a big seller, but had some customers that needed them.
Who needs them? Also the Badges will be ready Monday so I can set these up on the site to take advantage of combining. |
Mikey914 |
Mar 20 2015, 04:35 PM
Porsche 914 1.7 Early TPS board replacement
Application 1.7 Throttle Position Sensor (TPS) board replacement for ONLY the following unit VW/Porsche Part #022 906 111A Bosch part # 0 280 120 007 Instructions: Remove the 4 outside screws with standard #2 screwdriver Attached thumbnail(s) |
Mikey914 |
Mar 20 2015, 04:36 PM
Instructions:
Mikey914 |
When removing the cover, do not pull it all off. There are 2 sections, leave the connector section as close to the board as possible as there are wires you want to keep intact.
Mikey914 |
Mar 20 2015, 04:38 PM
Remove the center “back stop” section (pulls right out) Don’t loose washer
Mikey914 |
Mar 20 2015, 04:39 PM
removed
Mikey914 |
Mar 20 2015, 04:47 PM
Installed
Mikey914 |
Mar 20 2015, 04:48 PM
Put more detailed pics on my facebook page and the instructions will be more detailed also. The files were a bit large on the pics.
You get the idea. |
TheCabinetmaker |
Mar 21 2015, 06:21 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Do these not work for the 72-73 models?
Mar 21 2015, 06:38 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I'll take one. Thanks
Chris Pincetich |
Mar 21 2015, 08:13 PM
I got one of these from Mikey, did the install, and it solved my "stumble" I was experiencing around 2.8-3k RMPs. Thanks again! (IMG:style_emoticons/default/beerchug.gif)
I can add to the install advice: the old TPS board is glued on and I found that using the edge of a metal file allowed me to carefully grind through it so it could be picked off in pieces. I had never used a soldering iron before, but bought one for the TPS install. Easy! (IMG:style_emoticons/default/beerchug.gif) |
913B |
Mar 21 2015, 11:46 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Yeah I am in for one of these also
dlee6204 |
Mar 22 2015, 03:33 AM
I'm in for one
plas76targa |
Mar 22 2015, 08:15 AM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
I'd like one,please.
podiummotorsports |
Mar 22 2015, 11:08 AM
Newbie Group: Members Posts: 39 Joined: 7-October 12 From: Rossmoor, CA Member No.: 15,011 Region Association: Southern California |
I would like one.
podiummotorsports |
Mar 23 2015, 02:00 PM
Does anybody have a pic for a correctly setup TPS for the older 4 pin and two arm setup?
913B |
Mar 27 2015, 03:33 PM
Mark they are listed as $42 on your site. Was there a secret code or something for the GB pricing ?
And the 914 world badges ? Thanks in advance |
913B |
Mar 30 2015, 08:32 PM
I would like to combine this and the club badges, is the GB for 1.7 TPS over ? I never got any communication ?
Mikey914 |
Mar 30 2015, 10:27 PM
Yes I corrected the price on the website good til Monday.
Thx |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:33 AM |
