Mikey914
Mar 20 2015, 04:33 PM
Got the 1.7 Early 70-71 TPS boards done. Probably not a big seller, but had some customers that needed them.
Who needs them?
Also the Badges will be ready Monday so I can set these up on the site to take advantage of combining.
Mikey914
Mar 20 2015, 04:35 PM
Porsche 914 1.7 Early TPS board replacement
Application
1.7 Throttle Position Sensor (TPS) board replacement for ONLY the following unit
VW/Porsche Part #022 906 111A
Bosch part # 0 280 120 007
Instructions:
Remove the 4 outside screws with standard #2 screwdriver
Mikey914
Mar 20 2015, 04:36 PM
Instructions:
Mikey914
When removing the cover, do not pull it all off. There are 2 sections, leave the connector section as close to the board as possible as there are wires you want to keep intact.
Mikey914
Mar 20 2015, 04:38 PM
Remove the center “back stop” section (pulls right out) Don’t loose washer
Mikey914
Mar 20 2015, 04:39 PM
removed
Mikey914
Mar 20 2015, 04:47 PM
Installed
Mikey914
Mar 20 2015, 04:48 PM
Put more detailed pics on my facebook page and the instructions will be more detailed also. The files were a bit large on the pics.
You get the idea.
TheCabinetmaker
Mar 21 2015, 06:21 AM
Do these not work for the 72-73 models?
Mar 21 2015, 06:38 AM
I'll take one. Thanks
Chris Pincetich
Mar 21 2015, 08:13 PM
I got one of these from Mikey, did the install, and it solved my "stumble" I was experiencing around 2.8-3k RMPs. Thanks again!
I can add to the install advice: the old TPS board is glued on and I found that using the edge of a metal file allowed me to carefully grind through it so it could be picked off in pieces. I had never used a soldering iron before, but bought one for the TPS install. Easy!
913B
Mar 21 2015, 11:46 PM
Yeah I am in for one of these also
dlee6204
Mar 22 2015, 03:33 AM
I'm in for one
plas76targa
Mar 22 2015, 08:15 AM
I'd like one,please.
podiummotorsports
Mar 22 2015, 11:08 AM
I would like one.
podiummotorsports
Mar 23 2015, 02:00 PM
Does anybody have a pic for a correctly setup TPS for the older 4 pin and two arm setup?
913B
Mar 27 2015, 03:33 PM
Mark they are listed as $42 on your site. Was there a secret code or something for the GB pricing ?
And the 914 world badges ?
Thanks in advance
913B
Mar 30 2015, 08:32 PM
I would like to combine this and the club badges, is the GB for 1.7 TPS over ? I never got any communication ?
Mikey914
Mar 30 2015, 10:27 PM
Yes I corrected the price on the website good til Monday.
Thx
