Bouncing Speedo |
Bouncing Speedo |
gfg3 |
Mar 24 2015, 01:36 PM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
So my speedometer needle is bouncing a bit. Nothing earth shattering, say about 2 mph or so, but annoying none the less. I guess I could just try a little cable lube but previous experience on other cars says that probably something is loose, twisted or kinked. I checked the cable connection at the speedo and that's OK. Any advice before I go out and buy the lube?
George |
CptTripps |
Mar 24 2015, 01:41 PM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Nope. you nailed it. Cable lube should do the trick....
DavidSweden |
Mar 24 2015, 02:15 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
So my speedometer needle is bouncing a bit. Nothing earth shattering, say about 2 mph or so, but annoying none the less. I guess I could just try a little cable lube but previous experience on other cars says that probably something is loose, twisted or kinked. I checked the cable connection at the speedo and that's OK. Any advice before I go out and buy the lube? George I had the same problem, the cable was almost off just a few threads holding it together. Probably not what you want to hear. |
gfg3 |
Mar 24 2015, 02:51 PM
OK. Off to the store to buy cable lube.....before I deconstruct my interior to fix/replace the cable. But then again, my wife just said "who cares if you know exactly how fast you're going?" So, maybe I'll work on other things.
George |
Elliot Cannon |
Mar 24 2015, 03:41 PM
broken cable strand scraping on the housing.
Lo-Fi Version | Time is now: 17th May 2024 - 09:22 AM |
