Is it ok to sandblast a trasaxle? |
quadracerx |
Mar 27 2015, 10:41 PM
Member Group: Members Posts: 426 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
Ive heard differing opinions on whether to sandblast a transaxle...
Some say it dangerous because of the magnesium case? Some say it will leave a very rough surface? I called the guys who do most of my sandblasting and they say the can bake most of the grease off then blast it with lower pressure... So it should be ok? Your thoughts? Thanks, Steve |
McMark |
Mar 27 2015, 11:53 PM
Media blasting grit is magical. It will, no matter what you do, get into every passage, nook and cranny. You take a risk by using media on it. You can clean it well enough, but you must be completely thorough. Or use soda, which is water soluble.
Also note, the bare magnesium will corrode/oxidize. It should be coated with something to protect it. |
Mar 28 2015, 12:54 AM
VaccaRabite |
Mar 28 2015, 06:51 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I'd only blast it if the trans were completely taken apart and the plan was to clean it 100% inside and out afterwards.
You are better off with degreaser and a scraper and stiff brush. Zach |
rgalla9146 |
Mar 28 2015, 07:31 AM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
NO!
a few loose screws |
Mar 28 2015, 07:48 AM
Member Group: Members Posts: 168 Joined: 8-August 14 From: canada Member No.: 17,754 Region Association: None |
Just out of curiosity,can you use walnut, plastic or soda to blast the case? I know you don't want anything to embed in the case and start a reaction. Is it more about not removing the outer material, i.e. coating, or treatments from the factory?
Lo-Fi Version | Time is now: 20th May 2024 - 04:23 PM |
